0 Members and 1 Guest are viewing this topic. Read 73987 times.
Many of us will have to repair our older models now and then, but even this is a small price to pay to enjoy our Maggie's for our lifetime's.
One of the nice things, though, is that you can use the new adhesive and then the rebuild will last a lifetime.
Peter, tell me if I'm missing something here, but a planar woofer isn't a flat driver. It can't be, because there's no enclosure and dipole cancellation rolls off the low frequencies at 6 dB/octave below a point that depends on the physical size of the baffle size. So planar woofers are intentionally designed to have a rising bass response to compensate, basically by using an undersized motor. In addition, they can be tuned by altering diaphragm tension or segmenting the diaphragm, as in the tuning dots of the Maggies. This allows acoustic equalization -- within limits, the driver's amplitude response can be tuned to suit both the baffle and an average room (not all rooms -- some will have more bass, and some less, so you can only go for an average). Finally, you have the characteristics of the electrical crossover, which get superimposed on the mechanical response variations of the driver and the baffle.What this says to me is that a planar loudspeaker has to be considered as a system, with frequency response ultimately depending on a wide number of interacting factors. And the reason I mention that is that I'm not sure it's meaningful to talk about comparing such a driver in isolation. The moment it's in a baffle of a different size or used with a crossover that doesn't have the right electrical characteristics, its tuning will be off, and it will sound wrong. But I don't know the specifics of the transplant you performed, so this is more a question than anything else.I'd add that when I've spoken to people at Magnepan, they've always referred to "this sounds better" or "this sounds worse" or, not infrequently from Wendell, "That sounds terrible." The reason I mention that is that it's always been about fidelity. I can't imagine them intentionally designing in a coloration. You should have seen Wendell freak out when I first heard the Tri Center and it sounded too bright to me (he fixed the issue with the resistors), or when I heard a minor bump in the midbass the next day -- I had to dissuade him from diving in and fixing it, or I would never have had a chance to listen!Also, as far as drivers being better or worse, they won't release something in a new model until their listening panels agree that it sounds better. Mark Winey, for example, wouldn't agree to include the supertweeter in the 1.7 until all the guys from the factory had heard it and agreed that it was an improvement.Of course that's not to say that a new model is definitely better than an old, or that some people won't prefer the old. It's just by way of passing on the sense I have of their priorities and their operation. Just as some designers make SET amps and others make 1000 watt A/B behemoths, there are always going to be differences of opinion. But personally, I've never had the sense that they would release an upgrade that they didn't genuinely think improved the audio performance of their product. The overwhelming impression I have from meeting and talking to the people there is that they're audiophiles just like us, doing what they do not to make a buck (although as a business they have of course to stay profitable), but because they love it.
I am really beginning to wonder if we're even talking about the same speaker. What part of a maggie driver is not flat? Have you not seen one? As for the car analogies, everyone wants to believe what they want. If anyone is going to tell me you can't compare a 68' VW bug motor to a 68" Cougar motor if you stuck them in a 73" vega, that makes no sense. They can be made to fit, and the cougar motor would kill the other. If you don't think so.. I have no reply to that.I have been catching hell for years because I might make the slightest implication about what magnepan does, and here you are asking me outright policy questions. Whatever you or I think is irrelevant in any case and not germain to the topic, so please stop asking me policy questions about this company.The fact is we are both assuming, but do you believe what every PR man for every company says is always true? Then again the man is a salesman after all, by golly, they've never been known to stretch the truth.... have they?Finally, you are wrong about the new adhesive. I have already seen maggies with this in a state of delam. It does not appear to happen as easily but under the proper conditions it can still happen. The same protocols as always should be observed.
I am really beginning to wonder if we're even talking about the same speaker. What part of a maggie driver is not flat? Have you not seen one? I have been catching hell for years because I might make the slightest implication about what magnepan does, and here you are asking me outright policy questions. Whatever you or I think is irrelevant in any case and not germain to the topic, so please stop asking me policy questions about this company.The fact is we are both assuming, but do you believe what every PR man for every company says is always true? Then again the man is a salesman after all, by golly, they've never been known to stretch the truth.... have they?Finally, you are wrong about the new adhesive. I have already seen maggies with this in a state of delam. It does not appear to happen as easily but under the proper conditions it can still happen. The same protocols as always should be observed.
Likewise, regarding that quote from RClark, the observed outcome only demonstrates that the subjects preferred MGM’s over the 1.7’s in that specific demo-room, using a midmarket AV Marantz receiver. Period. First and foremost, we have no idea how optimal was the 1.7’s placing in that demo-room (in itself and relative to that of the MMG’s). In addition, we have no idea how the outcome would have been with the use of a higher quality amplifier (different topology, etc).
I've seen several people conclude on the basis of the dealer demonstration that a cheaper model is better than a more expensive one. Generally, what seems to happen is they'll listen again at another dealer, or get it home, and change their minds. Not saying that that would always happen, just that the vagaries of dealer demos (acoustics, placement, amplification, etc.) are such that they can't necessarily be relied on.Just pointing that out, while I know the MMG well, as I said, I haven't heard the 1.7 myself and I know that people don't always like the newer model as much as the old.
I've been conducting my own adhesive testing here at home.Halitosis seems to be the killer.
