Bryston BP26 placed upon MPS-2?
0 Members and 1 Guest are viewing this topic. Read 1488 times.
K.H.
« on: 26 Dec 2011, 10:52 am »
Is it ok to have the BP26 placed on top of the MPS-2 or do you recommend more distance between them?
larevoj
Re: Bryston BP26 placed upon MPS-2?
« Reply #1 on: 26 Dec 2011, 01:50 pm »
I think you have 1 or 2 db gain with MPS-2 on top of BP26. However after trying a number configuration I preferred the BP26 on a rack by itself isolated from other electronics particularly PSU.
K.H.
« Reply #2 on: 26 Dec 2011, 03:29 pm »
Thanks for your reply. To save space in my rack I had hoped I could place the BP26 upon the MPS-2.
won ton on
« Reply #3 on: 26 Dec 2011, 03:45 pm »
K.H.-i have mine on separate shelves too, but you might try some kind of cones or feet to separate them a bit.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 26 Dec 2011, 03:56 pm »
The MPS-2 is well shielded and the only difference we have measured in noise floor isif  the MPS-2 is on top it has about 2dB greater noise floor - at the levels we are discussing though it is probably a mute point.
james
