Would the Super Vs work in a small room?
0 Members and 1 Guest are viewing this topic. Read 3408 times.
Vedder323
  • vinyl reviews and more, check out Newrecordday.com
    • New Record Day
« on: 20 Dec 2011, 09:27 pm »
Ive been seriously thinking about pulling the trigger on the Super Vs but my listening room is only 12x11, would they even work well in a room so small?
Danny Richie
Re: Would the Super Vs work in a small room?
« Reply #1 on: 20 Dec 2011, 09:46 pm »
Not a problem. They will work well in a small room so long as you can get them at least 3 feet out from the back wall.
Being open baffle, they will not load the room like a typical speaker. And with the controls that you have on the servo amp, you can easily balance them in any room.
Vedder323
    • New Record Day
« Reply #2 on: 20 Dec 2011, 10:03 pm »
Hi Danny, 3 feet from the wall to the front of the speaker or the back?
cujobob
« Reply #3 on: 20 Dec 2011, 10:07 pm »
3 feet from the back of the speaker to the wall. Every speaker greatly benefits from being pulled into the room, but it's a bit of a must with some designs.
How far back would your seating be from the speakers?
Vedder323
    • New Record Day
« Reply #4 on: 20 Dec 2011, 10:18 pm »
Thats the issue, if im looking at the measurments right, its gonna be near field big time, like 3 feet...
celebrat
« Reply #5 on: 20 Dec 2011, 10:44 pm »
Nearfield is no problem with these speakers. I have been playing with set up and they are SUPER versatile
ebag4
« Reply #6 on: 20 Dec 2011, 11:09 pm »
I'm running V1s in a 12.5'x10.5' room, my setup is in a ~6' equilateral triangle, sounds fantastic, great bass!
Best,
Ed
kp93300
« Reply #7 on: 21 Dec 2011, 01:35 am »
Hi Danny
what is the optimum  side clearance for this speaker ?
thanks
kp93300
Danny Richie
« Reply #8 on: 21 Dec 2011, 02:20 am »
Hi Danny
thanks
kp93300
Personally I'd want two feet or more.
fcraven
  • Don't mess with this baritone
« Reply #9 on: 21 Dec 2011, 11:42 pm »
I had this odd, but perhaps functional, idea to put some wheels on a V1, V2, (V3) type open baffle speaker so that I could push the out of the way when not in use. My super sandbox subwoofer has wheels (thankfully). But wheels are so... not spikes.
Bizarroterl
« Reply #10 on: 22 Dec 2011, 12:00 am »
For the spacing out from the wall - Could you simulate some of that by treating the rear wall?  IE install 4" of cotton insulation from floor to 2' above the speaker and a couple feet to each side.
persisting1
« Reply #11 on: 22 Dec 2011, 12:40 am »
I believe Guy 13 has his V1 and V2 on wheels.
