0 Members and 1 Guest are viewing this topic. Read 4477 times.
Hi James,All of a sudden the 3 volume buttons on my BR2 quit working. BP26 does not respond at all. Everything else seems to work fine. BDA BDP BCD all respond as they should. So no battery-issue I guess? Any thoughts on what to do?Thanks,Marius
Try punching in the preamp code again on the remote. James
I already tried, does not work. I tried the Bryston Preamp Remote, and that one does work, so it's definitely a BR2 issue... Marius
Ok maybe give Mike Pickett a quick email in case I am missing something. How are you punching in the code?James
wait a minute, don;t you mean the button with 'preamp' in blue?
Yes the one in Bluejames
Hi James,Given the volume-issue on my BR2 some thought yet? Any suggestions I could consider?Thanks,Marius
Hi James,Please let me ask again. Volume still is not working....I mailed Mike as you suggested, but received no response.What to do? Try new batteries, maybe because the volume takes more power to change than the other buttons? (sounds silly, I know....)Thanks,Marius
Hi MariusSounds like it is defective so please contact the dealer for a replacement. James
Ok I will.Thanks,MArius
Hi Marius,Dan one of our engineers may have the answer to the remote problem - will send his response when I get to work.james
Re-program the BR2 for the BP26 as per instructions. BDA & BCD are preprogrammed.Replacing the batteries will definitely cause it to lose the BP26 setting.It’s possible the remote was dropped or something, causing the batteries to temporarily shift and the BR2 will lose its settings.Dan
