0 Members and 1 Guest are viewing this topic. Read 10916 times.
Nothing could be worse than what I have with this record, so what's the "dummy" version of record cleaning that I can verify?
Hi John,For really dirty records, I pretty much do what Wayner does... wash them in the sink with dish soap. The difference in my washing method is that I use two 5" dent pullers to cover the labels (one on each side), so that the labels do not get wet. The dent pullers also provide a handle to hold the record while washing it in the sink: http://www.autozone.com/autozone/accessories/3M-Double-handle-locking-suction-cup-dent-puller/_/N-25ytZ1z140d1;jsessionid=89DA7B8AE13D28DFC8BB8FF0DFD1339C.diyprod2-b2c3?counter=2&itemIdentifier=244789_0_0_I believe I paid $14.00 for two at my local auto store.It goes without saying, that you need to get every little bit of soap off of the record. Therefore, as a precautionary measure, and as a final rinse, I do throw them onto a vacuum record cleaning machine to suck out all the water, and it helps to dry the record. For that, I use my record cleaning solution du jour. For that matter, I've read that Wayner doesn't use record cleaning machines at all.I put the clean record in a fresh sleeve, and voila, good to go. Clean and quiet records. Hope this helps.Din
John,I've been cleaning my used records in the laundry tub with liquid dishwashing detergent and warm water for years. Yes, the label gets wet, but none have ever come off and if you let your records dry out a bit, they will be just fine. I like to use a 2 1/2" horse hair paint brush to help get the suds down in the grooves and do a circular pattern with the brush. Finally, I simply rinse of the suds completely, then using two old "fuzzy" bath towels, I put the record on one and use the other to dry off each side.I do another type of cleaning before every play. I make a mixture of 3 parts clean water (like filtered or reverse osmosis) to 1 part 99% alcohol and that goes into a spray (misting) bottle. I then spray my Discwasher brush with the mister until it's damp and clean the record side on the table, with the platter running, to further clean, remove dust and neutralize static.Soon, records are clean, shiny and even slippery.I've been doing this for ......well since I was a kid.Wayner
