0 Members and 1 Guest are viewing this topic. Read 10927 times.
I received a spin clean for Christmas so I had my first go at cleaning. This was my regimen for used, ugly, garage sale records I have collected. Figured I couldn't hurt them.First, I grab a 12 oz. can of Miller Lite. Apply to lips frequently.I cut some metal coat hangers to hold two lps.In the laundry tub I put in warm water and soap and used a big paint brush as Wayner suggests. Brush both sides, rinse with tap water and hang for a minute. Thinking of trimming the bristles short so they are firmer and stay perpendicular to the grooves better.I then place the lp in the spin clean and rotate three times in each direction. I'm using the cleaner that comes with the spin clean. Prop the lp up for a minute to drain then wipe both sides with the clothes that came with the spin clean to get 80% dry. Hang lp on hanger for final dry.Before I play I also do a few revs with the old discwasher brush from my youth and zerostat it too.I do about 10 records at a time and you can get a good rotation going to keep the process moving along.Don't expect to turn a used lp into a CD. I would like to see what a vac on the final step would be like. Maybe I'll take an Engelbert Humperdink lp and hit it with the shop vac and see.
If you've got a Spin Clean, why bother with all the other stuff?Skip the warm water and dish soap, that's always going to cause trouble later on, with residue, etc.
You'd be surprised how much cleaner your records will sound if you try a decent enzyme cleaner and an ultra pure water rinse.
Good start."Don't expect to turn a used lp into a CD"Why would you want to do that? Seriously, watch out for shop vacs. The vacuum is too strong. You might want to try a regular vac with a modified corner attachment. You plug the end and cut an 1/8" slit to suck up the fluid. Put velvet or something soft around the slit to prevent scratching. Like this:http://www.teresaudio.com/haven/cleaner/cleaner.html
I've been using an old junk table to hand spin and wash , use a Michel clamp to hold the record and spin , at the moment using NG pure solution with a VPI brush to spread the fluid . 5 or 10 turns in each direction and maybe a 30 second soak on real bad ones . then the little shop vac with modified crevice tool to lift off the fluid. I then use the DI water rinse with a 2nd crevice tool to dry it off . Then into a new fresh new poly sleeve. I have found that this works great on new LP's ,kills the static too and gets rid of those pops and ticks that seem to be pretty common on new pressings. Also for anyone looking for an easy solution for the crevice tool pads , Nitty Gritty sell stick on felt strips for their machines so that is what I am using
Lots of bottled cleaners are nothing more then someone's idea of a record cleaner.
