Bryston 28BSST-2 or 7BSST-2 with Conrad-Johnson ET5/GAT preamps ? ...
0 Members and 1 Guest are viewing this topic. Read 11855 times.
tdinut
  • Joe aka Joeinid on other forums.
    • Audioshark Forum
Hi,
Just wondering how well these amps and pre-amps go together? The output impedance of the conrad johnson preamps is 100 ohms for the ET5 and under 100 for the GAT. Would there be any issues I should be concerned about? Thanks for the guidance and help.
Joe
rayooo
no problem whatsoever!
I have driven several SS amps with ET-5, that newer FET output stage on the CJ's works fine with virtually anything you can throw at it.  50k input impedance on the Bryston's, no sweat.  ET-5 is by far the best sounding preamp I've ever owned.
tdinut
    • Audioshark Forum
I have to agree, yet the GAT still calls my name. Maybe the amps first then the GAT if necessary. Thanks for the input  ;)
Anyone using CJ pre-amps with Bryston?
rayooo
oh yea, even though I'm thrilled with the ET-5, It would just be fantastic to own a flagship GAT!!!   :thumb:
if you have not yet, have a look over at Audioaficionado, good groups of Bryston and CJ folks there.
VOLKS
Hi Joe.............i have a buddy that has the Bryston 14BSST2 paired with a CJ ET3 Preamp and it produces some of the sweetest passages in the music i have ever heard.......i would imagine the 28's or 7's would be just as good..He also uses the Bryston BCD-1 CD player......all in all a beautiful sounding combo.
tdinut
    • Audioshark Forum
Hi Michael,
I am torn between upgrading to the GAT or Getting the Brystons. What a choice!
Joe
JfTM
Hi Michael,
Joe
I build on a sonic style; what sound do you like?  The most variation (IMO) is in speakers.  I'd choose there first. Then fill to meet their needs :)
My experience with Bryston is that their gear adds as little as possible to the sound.  Don't look to Bryston to sweeten the mids, boost the lows, or any such like.
VOLKS
Hi Michael,
Joe
Wow............. either way you will have an amazing system indeed!!.....
tdinut
    • Audioshark Forum
Hi JfTM,
I have Nola Micros like my avatar and Klipsch Cornwall III's. I like a sweeter/warmer sound and hope the Conrad Johnson sound comes through Brystons. I can't get to hear any Brystons locally but people who's ears I trust, love the Brystons with a tube preamp and I am hoping for the same.
Joe
werd
Hi
You might want to consider the gain on your pre amps also. I see the Cj's at 25db which is higher. It will be loud thats for sure. If you want loud looks good but if you want it more casual laid back you will probably be switching the bryston amps to 2v lower gain setting.
tdinut
    • Audioshark Forum
Hi
That should not be a problem, correct?
werd
np at all
OgOgilby
Joe,
I'm going to have a CJ preamp and Bryston amp setup, but not quite the ones you are asking about. I have the CJ Premier 18LS (solid state, 22db gain) and today I put in an order for a 14B-SST2. I'm looking forward to hearing how the combo works.
Werd,
Does the Bryston amp gain switch work with the single ended connections that CJ's use? I thought I read somewhere that the gain switch was only for the amps balanced inputs.
-Greg
Diamond Dog
Joe,
-Greg
Hi :  My previous and current preamps were/are Manleys, both with only single-ended outs and the gain switches on my Bryston 7BSST2 work just fine in that configuration. No worries!
D.D.
tdinut
    • Audioshark Forum
Joe,
-Greg
Hi Greg,
Great! Please keep us posted on how the combo sounds. I am sure the amps will need some break in even though they are stressed at the factory. I am really interested in your findings with that combo. How long until everything comes together?
Joe
tdinut
    • Audioshark Forum
D.D.
Hi D.D.,
Cool! I have a pair of Manley Neo 250's (purchased on a whim) that I don't want to press into service because of the heat, 20 output tubes and 4(?) input tubes. My bedroom is my listening room, so the Manley 250's would be too much, that's one reason I want the Brystons. Another reason is all the buzz that's going around about these babies.
Joe
OgOgilby
D.D.
Thanks D.D., that's great to know!
-Greg
OgOgilby
Hi Greg,
Joe
Hi Joe,
I'll post my findings once the amp has settled into my system.
As far as to when things will come together - the amp is shipping Thursday (Dec 1st), so I'm not sure. I'd love it if the amp arrived before the weekend, but it is looking like next week.
-Greg
« Last Edit: 30 Nov 2011, 03:48 pm by OgOgilby »
tdinut
    • Audioshark Forum
Hi Joe,
-Greg
Excellent Greg!
Congrats on the purchase. The waiting is the hardest part. I am excited for you.
Joe
larevoj
Guys, I have read about CJ many times and really love what I read but just no opportunities to have a listen especially if you manage to compare CJ with equivalent ARC. Both CJ and ARC works well with Bryston amplifiers and IMHO both excels sonically but differs in character catering to different customer base.
Please keep us posted!  :thumb:
