DAC/preamp with HT bypass?
0 Members and 1 Guest are viewing this topic. Read 9929 times.
mca
« on: 17 Nov 2011, 05:15 am »
I know W4S makes such a product with the DAC2, anyone else come to mind?
jd3
Re: DAC/preamp with HT bypass?
« Reply #1 on: 17 Nov 2011, 10:22 am »
If I remember correctly, the Bel Canto dacs will allow ht bypass and can function as a full preamp.  I have a 2.5.
firedog
« Reply #2 on: 17 Nov 2011, 12:50 pm »
golfugh
  • Dead Can Dance - Into the Labyrinth
« Reply #3 on: 17 Nov 2011, 01:05 pm »
These come to mind:
Wyred DAC2
Antelope Zodiac
Benchmark DAC1Pre
PS Audio PW DAC
Berkley Alpha DAC
Bel Canto's DAC1.5, 2.5, 3.5VB
srb
« Reply #4 on: 17 Nov 2011, 01:16 pm »
These come to mind:
Wyred DAC2
Antelope Zodiac
Benchmark DAC1Pre
PS Audio PW DAC
Berkley Alpha DAC
While these units may all have preamp/volume control functions, I think only the Wyred DAC-2 and Bel Canto 2.5/3.5 have HT Bypass inputs?
pardales
« Reply #5 on: 17 Nov 2011, 01:37 pm »
I'm not sure if it has HT bypass or could be configured with such, but check out the Van Alstine Vision Pre/DAC.
« Last Edit: 17 Nov 2011, 03:01 pm by pardales »
golfugh
« Reply #6 on: 17 Nov 2011, 02:49 pm »
You are correct, my bad...missed the HT Bypass point.
Mark
skunark
« Reply #7 on: 17 Nov 2011, 05:17 pm »
These are preamps first, DACs second.. but still fits the bill.
McIntosh C48/C50
*believe it has a 12v trigger to enable passthru
*users have reported issues with the usb input on the dac
Classe CP-800
*believe this is remote only
SimAudio Moon 350P
mcoaggie
« Reply #8 on: 17 Nov 2011, 06:28 pm »
The peachtree nova had HT bypas and the new grand-pre as well.  I don't think the new nova (not out yet) will have it though.
avahifi
    • http://www.avahifi.com
« Reply #9 on: 17 Nov 2011, 06:47 pm »
The AVA Vision DAC/Preamp does indeed have a $50 HT Bypass option available.  www.avahifi.com
Frank Van Alstine
cliffy
« Reply #10 on: 18 Nov 2011, 02:16 am »
Bryston SP2 has a bypass function.
srb
« Reply #11 on: 18 Nov 2011, 02:30 am »
I believe the SP2 has an analog bypass to bypass any digital signal processing.  HT Bypass is a special input to allow bypassing of a preamp's volume control when connecting an AV Processor and using its volume control.  Since the SP2 is an AV processor, this type of input wouldn't apply.
cliffy
« Reply #12 on: 18 Nov 2011, 04:43 am »
Doh :duh:
Just got my SP2 hooked up today and am still reading thru the manual.  I only run stereo but wanted the DAC and the ability to decode DD and downmix from my cablebox (Won't output PCM from the digital out).
skunark
« Reply #13 on: 18 Nov 2011, 08:50 pm »
Bryston's BP16-DA preamp
*optional remote required to configure (or use rs-232 input)
*I believe the DAC works only up to 96/24 files.
Modwright LS-100 Tube Preamp
*Front panel operation.
mca
« Reply #14 on: 26 Nov 2011, 05:54 am »
Does anyone know what chip the new Bel Canto DAC's use? I can't seem to find that info anywhere.
srb
« Reply #15 on: 26 Nov 2011, 07:09 am »
The Bel Canto 1.5 and 2.5 use the Burr Brown PCM1796 and the 3.5VB uses the Burr Brown PCM1792.
clearlight
« Reply #16 on: 26 Nov 2011, 04:40 pm »
The Warpspeed Optocoupler, an apparently excellent sounding newer LDR passive volume control can do a HT bypass. The designer has configured it so that bypass happens on a second input while the unit is powered off. This is a fantastic option for those like myself who wish to run a dac direct to amp for maximum transparency but who also need to integrate an AV receiver into the system.
A future model with 3 inputs and two paralleled outputs (bi amping or sub output) is to be released, along with a remote volume control unit.
mca
« Reply #17 on: 26 Nov 2011, 06:01 pm »
srb, thanks for the info on the chips!
clearlight, thanks for the info on the Warpspeed, I send a message to the designer (?) to see if I can get some more info on these.
clearlight
