BDA1/BDP1 remote system
0 Members and 2 Guests are viewing this topic. Read 2501 times.
Robin1
« on: 28 Oct 2011, 08:22 pm »
hey guys I'm looking at moving in the near future .My question is once I get my theater room set up in the basement.....is there a way of hooking up my bda1,bdp1 to a reciever upstairs and still have it connected to my 4bsst,6bsst,sp-1.7 in the basement . Hope that doesn't sound too confusing   :)
JfTM
Re: BDA1/BDP1 remote system
« Reply #1 on: 29 Oct 2011, 11:31 am »
It's really a BDA connection question; the BDP would connect to it right?
I believe the BDA has both RCA and XLR outs.   Depending on distance you could use the RCAs to the nearer preamp and the XLRs to the other.
SHV
« Reply #2 on: 29 Oct 2011, 02:23 pm »
I use my BDA/BDP as a source for two separate systems.  The balanced out-put can be run for several hundred feet without a problem (according to "pro" sites).   The problem that you may have is "does your receiver have XLR inputs"?, the sp 1.7 doesn't.  I got a Parasound balanced  P3 pre-amp (<$850) to run my outdoor system.
terrycym
« Reply #3 on: 29 Oct 2011, 03:50 pm »
The balanced out-put can be run for several hundred feet without a problem (according to "pro" sites).   The problem that you may have is "does your receiver have XLR inputs"?.
In which case you run a XLR to RCA cable and don't connect the -ve wire but that rather negates the advantage of XLR.
SHV
« Reply #4 on: 29 Oct 2011, 04:28 pm »
Hadn't thought of that possibility, hence my C- rating. :>).  Does termination of a long balanced run to RCA affect the advantages of long balanced cable runs?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #5 on: 29 Oct 2011, 04:38 pm »
For a system to be balanced it must have both a balanced sending circuit and a balanced receiving circuit if common mode noise rejection etc. is going to be taken advantage off. Also there are a number of ways to build balanced circuits. Bryston uses full differential fully discrete Class A circuits.
James
SHV
« Reply #6 on: 29 Oct 2011, 05:04 pm »
"For a system to be balanced it must have both a balanced sending circuit and a balanced receiving circuit if common mode noise rejection etc."
So back to the OPs issue, for a long cable run (to  basement, etc.) the "cheat" of using an RCA termination won't work and a pre-amp/receiver with XLR balanced inputs is needed?
« Reply #7 on: 29 Oct 2011, 06:29 pm »
Hi Steve
It will work - it just will not be a balanced signal.
James
Robin1
« Reply #8 on: 29 Oct 2011, 09:34 pm »
thanks everybody...I'm not sure of the distance yet and I don't have a secondary reciever but knowing I can run that kind of distance I can start watching for a decent reciever or preamp/amp with xlr inputs.......probably just be for 2-channel music system. Just trying to plan ahead
thanks
Robin
JfTM
« Reply #9 on: 30 Oct 2011, 06:41 pm »
thanks
Robin
Bryston preamps come to mind  :thumb:
Robin1
« Reply #10 on: 30 Oct 2011, 09:52 pm »
was thinking the same thing.....hope my wife's not reading this
