0 Members and 2 Guests are viewing this topic. Read 978159 times.
Yes the 6B's are perfect - probably a little overkill on the tweets.I wanted to try them in a smaller room (12/18 - long wall). The nice thing about acoustic suspension speakers (sealed box - no ports) is they are really well controlled so it does not overload even a small room with low end which is usually the case with big speakers in small rooms. I am getting abour 25Hz at the low end so with the M80's I liked having the subs engaged but with the Model T - not needed!!!Having fun james
Hi James,If I'm reading correctly, it looks liKe 30 Hz to 17 KHz +/- 3db is the frequency response. In room, you would probably loose 2Kz or so off the top, due to absorbtion, so how does that impact their airiness, if it does, at all?
Hi SoundGame,Yes the nice thing about the DSP crossover is you can really fine tune the frequency response to a much greater degree than with passive networks and so far this result sounds the most balanced.james
I think measurments are idicative of performance james
..."The Demo IS Everything"
Very much in line with my experience, for this reason I do demo of components that measure well and more or less ignore those that do not.
Hi Folks,So we are going to build a Passive version of the Model T and do some listening comparisons.james
