0 Members and 1 Guest are viewing this topic. Read 90379 times.
BTW: I don't know if this was mentioned before, but the build document shows that the 0.22 uF capacitors were installed incorrectly. The +/- pads on the board are not oriented in the same way for both caps, which were installed assuming they were.What? More specifics please.
MATCHED/UNMATCHED FETSYou will need 4x matched 2SK170BLs per the BOM. Or you can order bulk from someplace like Ampslab and use the DMM measurement setupto match Idss. You will want 6mA or higher. This will be explained later.
Hi Wushuliu, Great Thread, Thank you.I just received some 2SK170BL's and need to match them.You mentioned that you would explain later how to match them but I can't find it in this thread.Can you explain how to match them and can it be done with a basic DMM? Thanks,Steve
hook up a simple jig with a 9v battery and a 100R resistor in series with the jfet and measure the voltage drop across the 100R resistor to find out the idss. do it with the rest to get your match.
Hmm, the text and the diagram seem to be two different setups. The resistor drawn on the diagram appears to be 1K (or possibly 4K - the person who drew the diagram was not taught how to write (draw?) by a Catholic nun, btw) and the voltage source, while it appears to have a "9" associated with it, has some other baffling squiggle preceding that 9.But yes, a voltage and a resistance, and then some type of Law.
