0 Members and 1 Guest are viewing this topic. Read 13554 times.
Hello WGH,Looks like you are the man with the two right hands.Hope you live nearby VSA?They can use your help in these days. Cor
A couple of thoughts about speaker modding:Your warranty - you probably have a 10 year warranty if you bought your speakers from an authorized VSA dealer, I don't know how my work effects the warranty.Shipping - you probably have a 50/50 chance of something getting damaged. Who pays if it happens? And what the heck do you do with one good speaker?I believe you can buy the custom Scanspeak drivers from VSA and do it yourself. 1" Richlite and No Rez will probably get real close to what the factory is doing.Luckily for azhtnut there is a modified LCR-15 (stock drivers) in Phoenix he can (maybe) listen to. If you get the Scanspeak upgrade for the VR4jr then I think the center should match as well. I did a demo with the VR2 on the left and the LCR-15 on the right and it sounded great with a solid center image, the only difference was less bass.Wayne
II'm a big fan of Kapok. The material is light as a feather but has the ability to damp resonances and standing waves much better than Dacron, I'm guessing by a factor of 2:1. A little goes a long way so I stuffed that little box full of Kapok. Wayne
