0 Members and 2 Guests are viewing this topic. Read 341219 times.
Have you tried the Obilgato's in the past and thought the bass was lacking? I tried the B1 board with old 10yr old slagle/intact audio autoformers (AVC) and couldn't get enough bass from it. Maybe my stacking of the cores wasn't right but I could never get deep bass from it in the past
Don't use a Pot mate. They're not going to impress you. Instead of use an eBay chinese DACT, and then add a remote control for it if you must have remote. Switching from a pot to one of those is close to the difference your B-1 made in my experience.
just purchased the legitimate B-1 Board with matched jfets from Nelson Pass via the store and printed out the BOM from the first pageI am thinking about upgradeing the resistors and caps, but after looking at the price of 4 Vishay tx 2575 resistors my fixed income budget got sticker shock.At the bottom of the BOM post on page 1 it mentions PRP resistors. for the thrifty audio fan , but the link to the retailer is changed and I couldn't find resistors marked PRP at the new site . Are these for the 4 1K input resistors people suggest upgrading ? I realize this is an older thread . I posted here because the other one is huge in length. Are the suggested bypass Dayton film/foil caps paralleled to get 1uF suggested upgrades for the metallized polypropelene caps in the digi-key BOM ?I use a couple of tube integrated amps, one a Class A and the other AB along with some AB solid state amps . Does the B-1 work well with tube amps ?thanks
Hello DIYer's,Wanted to say thank you to everyone that has contributed to this thread! I just finished my very first DIY build which was a ton of fun but would have been impossible without this thread as a resource. Check out the finished product below. Pass B-1 Dual Mono Integrated Amp: - Pass B-1 Buffer (BOM as listed by wushuliu) - Mundorf MCap EVO 10uf - Jantzen Superior ZCap MKP 1uf - IcePower 50asx2 - mono X2 - 25k Apls Pot - Velleman K1823 1A power supply - AnTek AN-0118 10VA Transformer - Aluminum amp enclosure WA11 (eBay)
We just replaced (with the help of a friend) the manual Alps Blue volume pot with a remote controlled TKD from Hi Fi Collective and the sound is noticeably better with greater clarity, air and detail. Textures are improved as well.
http://www.parts-express.com/pe/pshowdetl.cfm?PartNumber=027-932&DID=7
