0 Members and 2 Guests are viewing this topic. Read 385506 times.
Worked on B1 board today. Soldered the small resistors. Serious appreciation to Wushuliu for the run through. I used the soldering demos he linked to, and they were very helpful. Made some classic poor joints and think/hope have redone them well...trying to get the hang of small soldering. May get a big magnifying glass as my eyesight isn't really good enough for this small work. Have a good soldering station, but had to practice setting temperature and using best tip for the work. In college took jewelry/metalworking classes and one of the best things about it was working nights in the lab when everyone would help and encourage each other on our projects. Would be cool if my audio projects could be done that way, sure some folks arrange that with buddies.So, will try to make more time to finish this up soon, it's a short project but have a busy 2 weeks ahead at work.
Currently using 24v walwart, wiill get an 18v one to compare.
Hi everybody,as usual, sorry for my english first of all....Thank you very very much for this topic that helped me so much building also the second B1 buffer....This time I wanted a remote controlled unit, so I decided to use a cheap ebay pcb with remote to control a motorized pot on the Lightspeed attenuator kit by Uriah Dailey....These cheap remote pcb's are not so good for working on signal but using it only for controlling the 5v supply to the LDR's I don't risk any kind of noise....This time I used k73 caps bypassed by teflon k40, only precision resistors on board and 0,01% res on signal...This time I use three 6v sla batteries for 18v B1 psu and a simple charging/mantaining circuit for charging them....About Lightspeed attenuators everybody says that the 5v supply to the LDR's has to be the "cleanest" possible, so I used a JLH Ripple Eater after a simple 7805 regulator....With a 24v switching PSU and a simple quadripolar switch, with one movement, I can select between powering the charging/mantaining circuit or giving power to the 5v to LDR's, 18v to remote pcb and connecting batteries to B1... The sound of battery powered B1 with Lightspeed is IMHO very very good and I'm really happy I finally can sit on sofa controlling volume with the remote! I'm really becoming the italian version of Homer Simpson! Thank you very very much again for this really useful thread!
I'll have a couple extra sets of 1k and 220 ohm PRP resistors for $7 for anyone who wants to upgrade their resistors and/or lower their ouput impedance w/ the 220. This way you don't have to shell out minimum fees and ups shipping, etc. just to get them...
Thanks for sharing perfido. I think using the motorized remote with the lightspeed is brilliant. I'm sure it sounds amazing!
