Hi, Sorry for bringing this post back. i wanted to ask what the minimum/maximum voltage everyone is using. Reason i ask, is i have a power supply with a switch but the voltages are 13/30. would this PS work? thanks in advance,Ruphen
Anyone else? There seemed to be a great amount of interest when this project was first started?
Thx Nick77. You referring to the 1K resistors? What did you use ? Were you able to compare to original?
I was concerned about the length of wiring to each of the 6 inputsbut so far have not had any crosstalk. Yes I do need 6 inputs DAC (SB Touch to external dac), Vinyl, CD player, Tape deck, Reel 2 reel and a spare. also added a HT bypass so my kids could still hear their games via front channel speakers without having to mess with the input and volume. Worked out good.Thx again to all who have posted over the years.
Most felt lowering the value to 330r was best for sonics, so thats what i used.Lots of comparison, best to worst.....Vishay TX2575 Foil very resolute and neutral Riken Carbon warm and fairly resolutePRP Metal film good metal filmTakman Carbon, warm but conjested
