0 Members and 3 Guests are viewing this topic. Read 341637 times.
This canard about the "Tranquility DAC requires a Mac Mini" needs to be put to rest once and for all.I bought my Tranquility when I had a notebook computer as a source, and I was thrilled with it. It was clearly better than the PS Audio Link DAC III (with Cullen mods) that I was using.The Tranquility or Tranquility SE is the foundation of a system that you can live with happily over the long term. I did try the Mac Mini after a while (months) and things went from excellent to more excellent. I'm very glad that I had a DAC that had room to grow, so to speak.
Sorry, but I don't buy it. The better the receiver, the LESS sensitive it should be to the quality, or lack thereof, of the source. This isn't a linestage we're talking about where utter transparency to the source is the ideal. It's actually the opposite. Re-clockers like the Pace-car work not by being transparent to the source buy by scrubbing it clean. Didn't DB basically say that Asynchronous was not used for cost reasons? There is NO other reason I can think of not to use it.
Really, until youve listened to this dac with various source computers and software, and a few different cables, you're just guessing based on some faulty "common knowledge" that seems to float all over the audio forums.
I cannot agree more, as I have PERSONAL experience on various sources and in no way MUST you use a Mac Mini.
Having said that, I am curious to what power cords you guys are using with the Tranquility SE? I am using a Pangea 14SE right now and like the results - but I have limited cords to compare it to. I have a WyWires Juice power cord coming my way soon, so I'll have that to try out. I find power cords to usually have a pretty solid impact on a component's performance, so I'm just curious if any of you have tried multiple cords out on the Tranquility SE or if you find it doesn't have much of an impact.
Bit-perfect output should be enough.
BTW I happen to know the reason the Tranquility does not use async - it is because it would require proprietary drivers and not cost. They would spend the money if it would resolve all the issues - but it doesn't - whereas what they did choose was better. I also have heard a couple of async DAC's- and even own one - the WFS - and none are as good as the Tranquility. If you believe otherwise I suggest you get a Tranquility, get an async DAC and conduct your own comparison. I have done that and the Tranquility wins. If you want to go out and get a DAC like an overdrive and a pacecar - go ahead.
No. If they.....
Enough said.
Sorry, but that's not true.
Did DB say they basically demand that their customers get Mac Minis? Or did I make that up?
Whats not true? I am claiming that the standard USB drivers do not handle async right now? Are you claiming that is false?
Streamlength should not have this issue, so why doesn't the Tranquility use it? I still haven't gotten a good answer.
