0 Members and 1 Guest are viewing this topic. Read 341267 times.
I haven't as of yet graduated to a Mac Mini. I am still using a tweaked MacBook Pro and getting the aforementioned results. Therefore, I have no doubt in Eric's claims of a Mac Mini being a better player. I look forward to "upgrading" to a Mini in the new year.
Also, the fact that the Tranquility is SO sensitive to the source would seem to indicate that whatever special sauce is being applied to the USB implementation doesn't work.
I'm very curious if anyone has tried using the Vaunix Lab Brick USB Hub to send the USB signal, rather than straight out of the computer. One of the biggest problems with USB based audio is that the USB format itself was never designed for audiophile purposes. The signal and power sections are really not isolated at all. Getting the unnecessary bus power away from the DAC by using that Lab Brick rather than a motherboard USB port should provide some improvement, and for those using laptops, should eliminate the difference between battery and AC power. Another, much cheaper possibility is that since the Tranquility isn't bus powered, use a USB cable that has the power section disconnected, like the one available with the battery powered Hiface. Even the most expensive audiophile grade cable is still carrying 5V bus power that not only doesn't need to be there but is highly detrimental to the sound. Also, the fact that the Tranquility is SO sensitive to the source would seem to indicate that whatever special sauce is being applied to the USB implementation doesn't work. Any standard adaptive mode USB to SPdif converter has similar problems. Would using Streamlength add to the price of the DAC? Sure. More than the "required" tricked out Mac Mini? No. It would also open up 88.2, 96, 176.4, and 192. Which, let's face it, is the future of audio. ART makes the same argument with their Legato that 44.1 is all most people need, and that's probably true for a couple more years, max.
It doesn't indicate that to me - it indicates the 'special sauce' works extremely well because it is so transparent to what it is fed. Remember this DAC is designed by a top notch DAC expert - anything you can think of to make it better they would have thought of. The reason it is not used is it almost certainly is not theoretically better and/or a double blind test showed it was sonically inferior. The 'special sauce' is in fact the large amount of R&D that went into investigating just about anything you can think of. ThanksBill
The problem I see is that the dB Audio Labs DAC isn't cheap (at least not to me), and then to say that you have to buy the Mac Mini on top of that, really puts the price out of range.
Didn't DB basically say that Asynchronous was not used for cost reasons? There is NO other reason I can think of not to use it.
You can't do this in steps (buy the dac now and a Mini later)? The Mac Mini is only a recommendation.
This is exactly process. I have started using a Tranquility SE with my MacBook Pro. I will upgrade to a Mac Mini, etc. in steps. Nonetheless, the sound is outstanding.
