0 Members and 2 Guests are viewing this topic. Read 125534 times.
I am interested in a FLH project also. I have a small area that is going to be a "reading room" that will need a system. I am thinking one ST,FLH,Woofer,Sub. Do good mid FLH have to be 3' long?
Is this about crafting your own horn, or just using a premade horn to incorporate into a loudspeaker project?
Bigger horns can cover a wider bandwidth allowing for fewer drivers and fewer crossover points. Dispersion and driver integration issues can require a larger space as you need to have a certain listening distance for these to be effective.
Oblate spheroid
I chose the Gedlee speaks because I liked the science behind them. It made sense to me. I did not really research other horn types.
