0 Members and 1 Guest are viewing this topic. Read 142788 times.
Dan - I bet the doctor told you to take it easy. Do as you are told. Busy is not necessarily a virtue. It can be a debilitating distraction. We are human beings - not human doings. Meditate!
You can't EQ a polar response unless it's the same deviation at every angle. Making this crossover is sort of like squeezing a baloon as Zilch says. You can flatten it at one angle, but a bubble will pop up somewhere else. The only thing a device like that would help me with is the 9 and 12k dips. I think I may well know what the problem is there, but it isn't offensive so I'm not too worried about it at present. Right now I just want to spend a lot of time listening to music. It's been a week since my stereo has been fully operational.Dan
well, your response looks like the dips are pretty consistent, regardless of the angle. seems if you could use a deqx-type dewice to take care of it on-axis, then it would also be better off-axis...doug s.
Knock it off, Doug. Dan needs to rest up for now. He's convalescing.
dan, i am not the only one who thinks the deqx is the farthest thing from a band-aid. active x-overs rule, imo, and the deqx is simply taking things to another level.ymmv,doug s.
I have to agree with Doug on this. I am using a dbx Drive Rack PA which I have learned is an entry level product. It works pretty well but quieter, more flexible and more precise options exist. So, having learned that, I hastened to purchase an XTA DP 224 and promptly learned that I could drown in it. This thing supposes a level of computer competence to which I shall never attain. I'm currently seeking someone who can set and calibrate it for me. Unfortunately, where I live, I may as well be seeking people who knew Ben Franklin personally. Everywhere I call, including our local college, I find the same blank stares. Is there anyone out there in AC land who can bring me a remedy?
I think here is betterMy horn systems
