0 Members and 1 Guest are viewing this topic. Read 45641 times.
I enjoyed their description of the two prefabricated 55lb boxes as "specifically designed to maximize the sound potential".Looks like a slot in the front baffle with an open back (see 1:23 and 2:13 of http://www.youtube.com/watch?v=2ecC5LOabPY&feature=related)so we're talking OB in effect, it would seem. Moving mass of 1.5 kg? That's 3.3 lb! Insane.
i'd really like to recommend these in a theater design we have coming up. when will the first units be rolling off the production line? kevin, are you saying it's basically 1 driver and 2 passive radiators per recommended subwoofer enclosure, totalling about $2,000/subwoofer in raw parts?thanks,
Do I see 3 magnetic gaps in the motor? So I'm assuming the suspension is going to be the limiting factor in excursion on that monster. That is if you call 110mm one way "limiting". You know you could dye the surround on that thing pink and it still would be the toughest subwoofer out there.
Quote from: Steven Kephart on 2 May 2008, 06:42 amDo I see 3 magnetic gaps in the motor? So I'm assuming the suspension is going to be the limiting factor in excursion on that monster. That is if you call 110mm one way "limiting". You know you could dye the surround on that thing pink and it still would be the toughest subwoofer out there.Yes... three of them. Since this is an all-out project we are tooling both spider & surround. The spider landing is 14"!!!! Wiggins also has something evil planned that gives us more usable throw on the surround so the suspension will be able to fully support all of that excursion. That 110mm was just two-way x-max too. That is the 30% down point on the BL curve. If you use the standards that some companies use, the driver has around 124mm (mechanical limits) two-way. You won't be able to use it though. It takes something like 10-15KW in a box to bottom the driver so it's academic only.
Quote from: Kevin Haskins on 2 May 2008, 01:30 pmYes... three of them. Since this is an all-out project we are tooling both spider & surround. The spider landing is 14"!!!! Wiggins also has something evil planned that gives us more usable throw on the surround so the suspension will be able to fully support all of that excursion. That 110mm was just two-way x-max too. That is the 30% down point on the BL curve. If you use the standards that some companies use, the driver has around 124mm (mechanical limits) two-way. You won't be able to use it though. It takes something like 10-15KW in a box to bottom the driver so it's academic only. Kevin, I'm assuming that's in your recommended 10 cu ft box with dual PR's, right? I wonder how much power it would require to bottom a driver in a sealed or IB enclosure and eq'ed flat to say, 10hz? I'm guessing a lot less. What would the SPL be at the excursion limit?
Quote from: Kevin Haskins on 2 May 2008, 01:30 pmYes... three of them. Since this is an all-out project we are tooling both spider & surround. The spider landing is 14"!!!! Wiggins also has something evil planned that gives us more usable throw on the surround so the suspension will be able to fully support all of that excursion. That 110mm was just two-way x-max too. That is the 30% down point on the BL curve. If you use the standards that some companies use, the driver has around 124mm (mechanical limits) two-way. You won't be able to use it though. It takes something like 10-15KW in a box to bottom the driver so it's academic only. So this driver will have a one-way Xmax of 62mm? I thought that was about what the Jackhammer had. I'm pretty sure it had around 60mm one way excursion while the Parthenon had 80mm one way. I remember Dan commenting on how the Jackhammer had around 80% of the excursion of the Parthenon. Although I do believe the Xmax rating on the Jackhammer is obtained by the old gap height to coil height measurement and not from true large signal measurements. Please correct me if I'm wrong on any of this. As an academic project, do you have available the motor information for the Jackhammer? I'd love to see that information in an FEA program and see how how it fairs against it's rated specs. But then this is kind of getting away from the topic of this post.
It takes a little over 5000W in free air to bottom it. The SPL question can only be answered a specific frequency, dependent upon the installation, room and measurement distance. It is a thorny one to answer. And yes... I'm assuming a 10 cubic foot box with a 15Hz tune.
Hi Kevin,Any notable updates you may share?Larry
Here is the latest. This is the 21" basket, 14" spider landing and the motor using a 5" voice coil.
