0 Members and 1 Guest are viewing this topic. Read 24365 times.
As for actives, I am very much 'on the bus'. Thanks to input from JLM and others, I use a pair of KH120s in our basement A/V system and love them in a small space. I have a pair of JBL LSR305's (which for the $119 I paid for them are INCREDIBLY good) in my desktop work-from-home rig. However, the aesthetic issue might be huge with the larger JBLs in a living room setting. In addition, as much as I like the 305s in a nearfield setup, I wonder if the larger JBLs would serve well as my main listening outlet. I heard the ENORMOUS JBLs at AXPONA (are they the M2s?) both this year and last, and I don't think they are my cup-of-tea, even if I could handle the space constraints and cost. I will definitely have to seek out a demo of the 708p to see if they'd work for me. Where would one even find these? At something like a Guitar Center or similar pro outlet? -dB
This.
Tekton Impact Monitors
The JBL 705p or 708p could be in the mix. Hit most of your criteria except for perhaps the asthetic part.Active, powered monitors, neutral, clarity and extension. Find somewhere which you can purchase with a trial period.
The Selah's are VERY conservatively rated. I owned a Edge M6 at 120/watts per channel and it drove the Tempestas with ease. My brother now owns them and drives them with a Japanese home theater amp at 100 watts per ch. He says no problem getting great volume at reasonable levels on the volume control.
Soooooo, has anyone heard the 708p's in action? American Musical Supply lists that these are coming out 6/26/17. Care to comment how they sound and whether they might have any drawbacks in a home living space (as opposed to a recording studio)?Also, I notice these have two 250w Class D amplifiers for the high-/low-end. Does JBL make its own Class D amplification? Or do they outsource their amps to someone we might associate more closely with Class D amps?-dB
Personally I don't get it. They are doing a very crude version of a waveguide plus CD but with purposeful comb filtering at HF...not even a very intelligent dispersion matching if evenly distributed amongst tweeters
But it shur looks purty......
+3 If I had....I mean really HAD to downsize, this would likely be my only consideration.
Bluemeanies, have you heard these yet? Are they around anywhere that one could listen to these? It looks interesting, but I am unsure of the reasoning for 7(!) tweeters arranged in a honeycomb pattern. Doesn't that detract from the point-source concept? Wouldn't the drivers have to be extremely well-matched?-dB
Tekton Impact Monitors - Proprietary 3-way loudspeaker design. Not saying it works, not saying it doesn't.
