Impertinent half serious question...
0 Members and 1 Guest are viewing this topic. Read 18512 times.
Danny Richie
Re: Impertinent half serious question...
« Reply #100 on: 21 Feb 2017, 02:30 pm »
That's true except that the crossover can also change impedance. In some cases the components in shunt will lower the impedance, and inline resistors or L-pads can be used to raise it.
aceinc
« Reply #101 on: 21 Feb 2017, 08:50 pm »
Danny, a related question.
Given two 4 ohm woofers rated at 89 DB @ 2.83v efficiency are hooked up in series yielding a nominal 8 ohm load and an 8 ohm tweeter rated at 89 DB @2.83v efficiency, using a standard first order crossover, what would the relative efficiency between the woofer and tweeter section be?
Would the woofer section and tweeter both produce 89 DB? (at 2.83v)
Danny Richie
« Reply #102 on: 21 Feb 2017, 09:22 pm »
Yes, they would technically hit 89db. But that doesn't take into account baffle step loss.
And if you find a woofer that will cross to a tweeter using only a first order crossover then let me know. I have yet to find one. Even our woofers (that are really smooth) still like a second order slope best.
aceinc
« Reply #103 on: 21 Feb 2017, 09:37 pm »
Danny, that was a hypothetical question to make sure I understood basic information, namely that two woofers in series will double the impedance and not increase the efficiency.
I believe the reverse would be true that two woofers in parallel will halve the impedance and increase the efficiency by 3 DB.
I assume a second order crossover will not change the efficiency either, unless additional tweaks are added.
Danny Richie
« Reply #104 on: 22 Feb 2017, 07:10 pm »
Yes, that is correct. But halving the impedance might also increase the current from the amplifier and give you additional output.
The order of the crossover will not change the efficiency.
