Bryston BDP-Pi
0 Members and 1 Guest are viewing this topic. Read 100685 times.
matthewpartrick
  • vinnierossiforum.com
    • The Clueless Audiophile
Re: Bryston BDP-Pi
« Reply #120 on: 6 Jan 2017, 09:15 am »
Can I ask a simple question about the screen shutting down with USB output--is this a noise control issue, and is there a way around it? How would I enjoy the display, but making the device output through hdmi or spdif?
schmidtmike76
Re: Bryston BDP-Pi
« Reply #121 on: 24 Jan 2017, 02:46 pm »
Hi James I just updated my Pi but all my files have disappeared.  I'm so terrible with this but it looks like it's not finding my hd attached to it.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston BDP-Pi
« Reply #122 on: 24 Jan 2017, 02:52 pm »
Ok will forward this to Chris to help.
james
CanadianMaestro
Re: Bryston BDP-Pi
« Reply #123 on: 24 Jan 2017, 02:54 pm »
Mike,
Try unplugging the Pi. Then reconnect your external drive to Pi. Power up Pi.
I had a similar situation with my BDP-1 a long time ago.
schmidtmike76
Re: Bryston BDP-Pi
« Reply #124 on: 24 Jan 2017, 05:32 pm »
Thanks James
schmidtmike76
Re: Bryston BDP-Pi
« Reply #125 on: 24 Jan 2017, 05:34 pm »
Mike,
I did try that several times.  I have it in service mode until Chris calls back.  It sees the Seagate drive but not the files.  I'm sure a easy fix!
schmidtmike76
Re: Bryston BDP-Pi
« Reply #126 on: 24 Jan 2017, 07:38 pm »
Everything is back to 100%.  Thanks Chris
unincognito
    • bryston.com
Re: Bryston BDP-Pi
« Reply #127 on: 25 Jan 2017, 01:58 am »
The drive appeared to have been unmounted for some reason, not sure why
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
Re: Bryston BDP-Pi
« Reply #128 on: 25 Jan 2017, 04:54 pm »
Bryston BDP-PI Tinker?
Asus created a seriously more powerful competitor called the Tinker Board. It does look interesting...
unincognito
    • bryston.com
Re: Bryston BDP-Pi
« Reply #129 on: 26 Jan 2017, 12:58 am »
Yah thats not there first go at copying the Pi, one of there other companies Aaeon released this
http://up-shop.org/up-boards/44-up-board-4gb-ram-64-gb-emmc.html
Re: Bryston BDP-Pi
« Reply #130 on: 28 Jan 2017, 09:36 pm »
witchdoctor
Re: Bryston BDP-Pi
« Reply #131 on: 29 Jan 2017, 12:52 am »
http://av2day.com/2017/01/bryston-bdp-pi/
james
Nice review, I didn't realize this was HDMI compatible.
schmidtmike76
Re: Bryston BDP-Pi
« Reply #132 on: 30 Jan 2017, 10:48 pm »
I just updated on my iPad and now it cannot find server?
Re: Bryston BDP-Pi
« Reply #133 on: 30 Jan 2017, 11:05 pm »
Hi
Make sure you have the correct IP address in the browser.
james
schmidtmike76
Re: Bryston BDP-Pi
« Reply #134 on: 31 Jan 2017, 12:37 am »
All fixed.  you were right I just had to renew the IP, thanks James
mnorman
Re: Bryston BDP-Pi
« Reply #135 on: 1 Feb 2017, 04:21 pm »
I am a frequent reader of Bryston circles and a long time owner  :D. I have a question I hope some members can provide feedback on. Using the coax out on a BDP-1 or BDP-2 with the older sound card how does the sound compare to the Pi? Very happy with the SQ of my BDP-1 and can get another NOS from a dealer for around the same price as a Pi. Not sure which one would be the best sound.
Look forward to hearing about other members experiences.
Mike
schmidtmike76
Re: Bryston BDP-Pi
« Reply #136 on: 27 Feb 2017, 04:13 pm »
James Im unable to update my Pi.  I lost connection as it said server was down, dont know what that means.  I shut it down restarted still bricked, I unplugged the hard drive and then it read that but still not able to update?  IP address seems to be right
Re: Bryston BDP-Pi
« Reply #137 on: 27 Feb 2017, 04:15 pm »
So it works but no update available?
james
schmidtmike76
Re: Bryston BDP-Pi
« Reply #138 on: 27 Feb 2017, 05:13 pm »
Yes it works but is unable to update and it took two days to get it from its bricked stage.
schmidtmike76
Re: Bryston BDP-Pi
« Reply #139 on: 5 Mar 2017, 02:06 am »
James I messed up by deleting a radio station.  I added it to my playlist then I deleted it fron the playlist but now it's missing from the pop menu all together.  It was 181.1 under pop no sub menu how do I get it back?
