0 Members and 1 Guest are viewing this topic. Read 14822 times.
hello , to achieve a good open baffle system, you need speaker QTS high, from 0.8 is possible but greater than 1 is ideal, avoid speaker with QTS less than 0.7, the color and aesthetics of open baffle does not solve the audio quality problems the good speaker 10 "http://www.conrad.fr/ce/fr/product/1332722/Haut-parleur-10-Monacor-SPP-250/?utm_source=google-search-product&utm_medium=comparateur&utm_campaign=1332722&WT.mc_id=comparateur-gsp-1332722&LGWCODE=1332722;43857;390&gclid=CLGWteC-wcwCFSsz0wodLxoATghttp://www.bcorde.com/10ag-n-p1027793-1.htmlhttp://www.toutlehautparleur.com/media/catalog/product/datasheet/beyma/HP10-8.pdffor 15" and 18" , it's possible with TS 38 800pro and TS 45 1000pro http://www.toutlehautparleur.com/europsonic-ts38-800pro.html
Gils, thanks for your reply. Do you know if the Conrad's are available in the U.S.?
Alpha 15 is good because QTS = 1.56
QTS is 1.26QES is 1.53http://www.eminence.com/pdf/Alpha_15A.pdfA QTS=1.00 will show a less soft bass than the Alpha.
QTS 0.27 and 85 db !!
