0 Members and 1 Guest are viewing this topic. Read 6217 times.
Guess what ? I unplug the power cable overnight and restart it today, strange the problem disappeared. I am going to let it run for awhile and will keep you posted. By the way, the DSD sound perfectly and I quite like it. Hope the issue really solved Thank you
Sadly, when I use the remote to change the PHASE , the issue is back and I have to unplug the power cord and to restart it. Now it is back to nomal. Seem the changing PHRASE causing the problem
After a month listening, really love the sound, however, i spotted today that the right amd left balance only showed three steps instead of 12, needed to reboot to make it back to normal。
Thank you for the reply. I am using only the DAC part and the volume was between 55 to 60. Sometimes it only showed 3 after reboot it is now 12. I am not sure but I feel that after a period of listening time , sound quality turn to be odd and every reboot helps the sound quality (or to be exact back to normal)
