0 Members and 1 Guest are viewing this topic. Read 77062 times.
Isn't that the stuff most diffusers are made from these days? I think it can handle as low as 3-500 hz if it's the same material.
http://www.amazon.com/Expanded-Polystyrene-Foam-Sheets-qty/dp/B0054R8Y20/ref=sr_1_2?ie=UTF8&qid=1366257345&sr=8-2&keywords=eps+foamMaybe glue a couple back to back for 8" depth and use a QRD calculator and a saw?
Home Depot's got 2" by 2ft by 4ft styro for $6.29 a sheet. I'm all over it.
Don't blame you. You might also think about sewing and craft stores, like Michaels (I believe they're nationwide) as they might come in different colors.Nothing at all wrong with DIY room treatments. I suppose it is okay for DIY electronics, but not room tx...Jim
The pros here can correct me if I'm wrong, but AFAIK, the placement of the diffusers for the rear wave should be placed the same as one would do absorbers, in other words, get a mirror up against the wall and place the diffuser in the spot you see the back of the speaker (in the mirror) from your listening chair.BTW, I feel your pain. I've been saving up for a couple of boxes of GIK foam diffusers. But now camping season is here and I need all sorts of stuff for the RV...
So is your plan to build one large panel or 2 separate ones.You probably know about QRDude calculator, if not you do now..... I work with styrofoam and used a hot wire table to cut mine, butyou would be better to cut it with a saw, a table saw would be best.Youve prob seen this, but if not, heres a few shots of when I built mine.There may be a tip or two in for you in there......HAVE FUN!! thats the main thing.http://www.audiocircle.com/index.php?topic=96222.msg1035197#msg1035197
