0 Members and 2 Guests are viewing this topic. Read 114705 times.
From what I understand, the ideal diffuser type for Maggies is the QRD type that spreads horzontally, not both horizontal and vertical. To 500hz is fine, the eventual Dual Core and some bass traps will take care of below that. The Maggies don't load the room very hard, at least compared to anything else I've ever used, there's lots of bass, but the room doesn't bloat up like it always had before.
Always thought your listening space looked awesome. Yeah, that's about what I have pictured as far as the diffuser. I think I want to build 3 seperate panels and mess with them, place them all together, space them out, try all sorts of configurations.
Not according to Josh358 who advised me to go with both horizontal and vertical diffusion. Jim
I'd try and keep the sound energy in the horizontal plane rather than sending it towards the ceiling and the floor. Psychoacoustically I feel that is better because it gives you more sound energy arriving from lateral angles which improves perceived soundstage spaciousness.
Yeah I've never seen 2D diffusers recommended for Maggies before, that's a first. Every Maggie system I've come across in treated rooms has 1D diffusers in the back, and are recommended.@Nyall, thanks for stopping in. I think I'll do the QRD type. I haven't checked into a calculator yet. Is there one you can recommend or are they all the same?Also, if I cut a pattern for an 8' * 4' diffuser, and but in three sections that can be seperated, is that bad? Or should I have three seperate smaller diffusers with their own complete QRD pattern? Does that question even make sense?@JK, thanks for the tip, I'll look into that.
That is a very cool and simple arrangement. In the past, I have experimented with acoustic tiles(2 per panel), and made a sort L shaped piece that could be hinged, allowing multiple angles. Placement was wherever it needed to be around the speakers with VERY good results when placed in the correct spot. Maybe I will try it again.
Good choice. Allen is studio engineer and has tuned many of the studio's in and around Nashville.
Rodge:Do you by chance know Rick Vito, he's a killer guitarist and lives in Franklin....Jim
