LS 100 Balance input / output question ?
0 Members and 1 Guest are viewing this topic. Read 3231 times.
Teyry
« on: 28 Oct 2011, 12:50 am »
Are there any sonic advantages (noise reduction/noise cancelling) by having a single ended wired preamp with balance outputs as in the LS 100?
Also would there be any advantage of using longer balance cables to monoblocks positioned by the speakers with this type of preamp ?
dminches
Re: LS 100 Balance input / output question ?
« Reply #1 on: 28 Oct 2011, 02:03 am »
I don't think so since the XLR connections are not balanced.
Teyry
« Reply #2 on: 28 Oct 2011, 09:53 am »
I was thinking the same thing. It seems like having balanced connectors on a single ended design may be just for convenience.
modwright
    • ModWright Instruments
« Reply #3 on: 11 Mar 2012, 07:34 pm »
Sorry for very tardy reply, but that is absolutely correct.  XLR inputs and outputs on LS 100 are ONLY for convenience.  It is not a balanced design.
I have found, however, that using XLR cables with the LS 100 does help to keep noise levels down, as XLR cables offer better shielding, especially for cables over 1m.
Dan
« Last Edit: 21 Jan 2016, 05:28 pm by modwright »
Teyry
« Reply #4 on: 19 Aug 2013, 10:41 pm »
and I just ordered one in black with the phono stage.
