Speaker cable recommendations needed for Alpha's.
0 Members and 1 Guest are viewing this topic. Read 2134 times.
Maggie Guy
« on: 26 Apr 2004, 02:00 pm »
Due to unforseen circumstances I have moved my Alpha's to a new location and driving them with an Antique Soundlabs 30 watt tube amp.
Moving the Alpha's was a bit of an ordeal, but now that they are setup in their new home they are sounding as good as ever. I am temporarily using some Monster 16 guage speaker wire and am looking for some recommendations for some better speaker cables. Any input is appreciated.
JoshK
« Reply #1 on: 26 Apr 2004, 02:10 pm »
I highly recommend if you have any DIY inkling at all that you check out Apex Jr. Silver plated copper wire (Danny's recommendation) in a star quad geometry.  PM me if you need a little bit more of an explanation in the how to, but it is really easy and you need minimal tools.
Maggie Guy
« Reply #2 on: 26 Apr 2004, 02:31 pm »
Thanks Josh,
I purchased my internal wiring for the Alpha's from Apex Jr. I will send you a pm to get the details on the speaker wire.
Maggie Guy
« Reply #3 on: 26 Apr 2004, 05:27 pm »
Josh,
I accidentally deleted your PM so if you would be kind enough to resend.
JoshK
« Reply #4 on: 26 Apr 2004, 05:28 pm »
all I said in my email was that I was going to respond to you publicly in 'the lab'.  See my response there.
Maggie Guy
« Reply #5 on: 26 Apr 2004, 05:41 pm »
Thanks Josh,
Sorry for the misunderstanding.
