0 Members and 1 Guest are viewing this topic. Read 5791 times.
It's been more than 100 hours and the harshness is still very much around. I read that Mundorfs take at least 250 hours of burn-in. Patience, patience.
The new Duelund Alexander caps I had installed in my amp took about 500 hours. The sound was very fatiguing until then. I almost gave up.
250 hours to burn them in? It probably took 250 hours for you to get used to the new sound! Psychoacoustics.
I could never get used to any inferior sound no matter how long the process. Especially the treble and upper midrange region. Do you believe the manufactures are dishonest when they recco break in ? Or the speaker manufactures who say the same. Or you just having some fun breaking chops ?? charlesSMA
Also, I find it really really hard to believe that the highest quality teflon capacitors would be harsh, grainy strait out of the box. Exactly how many electrons does it take to "condition" a new capacitor anyway?
Speakers are stiff straight out of the box. If you were to measure Thiele/Small parameters before and after, they change over an extended period of time, even on a daily basis as the temperature changes. Eventually at some point they are broken in. However if left sitting or unused for any period of time they actually revert to being stiff again.Are you familiar with "shot" noise? An especially well known phenomena with resistors. That is why thermal stability is so important and one of the reasons why it's so good to keep your electronics on all the time. Avoid having to warm them up again.Now when it comes to capacitors, I read multiple suggestions at every other website. Someone says 250 hours, the next guy says 400 hours and then a third guy says 500 hours. So, I'm very, very skeptical. Also, I find it really really hard to believe that the highest quality teflon capacitors would be harsh, grainy strait out of the box. Exactly how many electrons does it take to "condition" a new capacitor anyway? So yes, I was busting chops.Psychoacoustics; usually more psycho than acoustic. No kidding, really. If people believe it sounds bad then it does and if people believe it sounds good then it does. Preconceived ideas influence our expectations. Just like that expensive bottle of wine or liquor that always tastes better than the cheap stuff. That is until the participants in the taste test discover it was a psychology experiment and that the testers only switched the bottles but not the contents.So, if you are a vodka drinker, top shelf stuff like Grey Goose isn't the best, only more expensive! But this has nothing to do with audio or does it?
