0 Members and 1 Guest are viewing this topic. Read 2903 times.
For those that have installed a sub-panel with dedicated circuits to feed your audio system, did you run 240v from the mains panel to the sub-panel, dropping it to 120V (20A circuits) at the sub-panel, or did you connect the sub-panel to the mains with a single phase 120V connection?I would imagine that running 240V to the sub-panel would give you better common mode noise rejection on that run, but the consequence is the need to pull from both phases in your mains panel. This would presumably negate the value of moving all circuits feeding motors (HVAC, refrigerator, washer/dryer, etc.) on the opposite phase of your audio circuits.
For those that have installed a sub-panel with dedicated circuits to feed your audio system, did you run 240v from the mains panel to the sub-panel, dropping it to 120V (20A circuits) at the sub-panel, or did you connect the sub-panel to the mains with a single phase 120V connection?I would imagine that running 240V to the sub-panel would give you better common mode noise rejection on that run, but the consequence is the need to pull from both phases in your mains panel. This would presumably negate the value of moving all circuits feeding motors (HVAC, refrigerator, washer/dryer, etc.) on the opposite phase of your audio circuits.I wasn't seeing much benefit to the 240V connection in this case, but I didn't know if I was missing something fundamental...Thanks for any comments!
