The Worlds Best AC Power Conditioning Products! Bar none!
0 Members and 1 Guest are viewing this topic. Read 3584 times.
ASi_TEK
  • NO LIMITS!!!
    • www.asi-tek.com
Have you been searching for the most resolution and dynamics out of your audio/video system?
Do you currently have power conditioning products in your system and you think the results are subpar? Or better yet, do you want the best power conditioning products in the world??? Do you have to wait until 4am on the weekends just to get half-way decent sound?
But the most is do you want the best resolution and dynamics IN THE WORLD??
We here at Reference Audio Mods have the Power Conditioning solution for you that cannot be found anywhere else!
AUDIO CONSULTING AC Mains Conditioning Transformers!!!
A COMPLETE WHOLE NEW WORLD OF MUSIC!
You have not and WILL NOT ever hear startling dynamics and utmost resolution with any other product.
These transformers eliminate the needs for recreating the AC sine wave with products that contain active circuitry. Well we know this looks good on the oscilloscope, the actual energy transfer function is extremely limited. With all the products we’ve tried on the market, they ALL limit dynamics and resolution due to this energy transfer problem they contain.
These also make video look so much better! Much better color tonality!!
There are three levels of Mains Isolation Transformers to choose from.
The first level is a 1500va version that is recommended for use for all system components AC lines to be dedicated and connect to. This handmade copper wired transformer can be used in a 1:1 ratio or 1:0.5 ratios. With the transformer we highly recommend using two 115vac phases (230v) and using the 1:0.5 tap. The creates a BRAND NEW 115VAC LINE. What is best is now there is NO MORE NEUTRAL LINE. This eliminates a whole load of noise and now you have blacker backgrounds and more punch. You will be amazed at the difference this unit makes in your system. The results when using this 1500va transformer with digital components are much more micro/macro resolution, taller/wider soundstages, much less grain/glare, and much more dynamics and bass!!!
Second Level- CD Mains 120va Isolation Transformer- This handmade copper wired transformer can be actually used stand alone from the much larger version above. This transformer connects to your dedicated AC line between the breakers and the AC outlet. We highly suggest using this for your CD/DVD/SACD players or transports/DAC’s. Or if you using the 1500va version, we Highly Recommend using this transformer as well in a 1:1 ratio in series to further isolate “Crosstalk” from other components in the system as well as provide even more isolation from those pesky harmonics from entering into your precious digital equipment. Also, this transformer can be wired to a 1:0.5 ratio and when you use two separate 115vac phases we once again can effectively eliminate the neutral on the system. We highly recommend also using the 1500va in conjunction with this great transformer for the best results! The results when using this 120va transformer with digital components are much more micro/macro resolution, taller/wider soundstages, much less grain/glare, and much more dynamics and bass!!!
Third Level- The Audio Consulting SILVER ROCK Mains Isolation Transformer-
This is the very best Mains transformer in the world. Made up of multiple thin strands of Audio Consulting SILVER WIRE, this little 35VA transformer will surprise the dickens out of you. This transformer set the standards anywhere with its World Class performance. At its 35va current potential, we highly suggest using this unit for your digital devices only. It is a complete optimized version of the CD mains 120va version. With its unique impedance ratings, the harmonics on the AC signal will want to travel anywhere but very far away. It can also be wired the same way as the above. The amount of energy created and resolution from this piece is completely and utterly stunning. The amount of resolution and effortless sound created cannot be matched.
Copper Wired or Silver Wired AC Digital Chokes-
These chokes would be wired in series with one of the above transformers, feeding harmonic correction to your very critical digital gear. The recommended setup is the CD Mains 120va transformer ($230/ea) with a set of the Copper wired Chokes ($260/set) wired in series to each other and then the output goes to the digital wall outlet. This will bring Resolution and Dynamics you never thought of. This combo will block alot of harmonics from entering through. Great Combo.
For the people who want the very best in performance (Live Sound) and have the budget, we HIGHLY RECOMMEND the Silver Wired 35va Silver Rock transformer ($1200/ea) and the SIGNATURE Silver wired AC Chokes ($1200/set)  together for the WORLDS BEST digital AC power conditioning. PERIOD. The results with this exotic combo is completely stunning and the music will sound LIVE. We have floored too many people with this setup.  The current limit is 20watts, please make sure your CD or DVD player draws less than this. We highly recommend wiring these components to your wall outlet with one strand of 24awg Audio Consulting silver wire with cotton sleeving (mandatory, high voltage).
Prices:
CD Mains 120va Mains Isolation Transformer $230 each
1500va System Mains Isolation Transformer $1180 each
SILVER ROCK 35va “Digital” Mains Isolation Transformer $1200 each(The worlds best)
Copper Digital Mains Chokes $260/set 30 watt limit!!!
SILVER ROCK SIGNATURE Silver Wire Digital Mains Chokes $1200/set
(The Worlds best chokes) 20watt limit!!!
We highly recommend using a competent electrician to install these products on a shelf protected away from pets or children. We can supply wiring diagram schematics if necessary. We assume no liability associated with product usage. The buyer is liable and responsible for any loss, damage or expenses of any kind, arising out of the use or misuse of these products. By placing an order, the buyer signifies agreement to these Terms of Sale.
Please email [email protected] or call Kyle at 909-780-2869 for any questions/purchasing these awesome products.
Please visit www.referenceaudiomods.com to purchase these transformers and the world’s best parts for replacement purposes for Tube amps, digital amps, CD/DVD/SACD players and more. We offer modification packages for many units and can design and install one for you if it is not listed.
1500VA System Mains Transformer! $1180/each
120va CD Mains Transformer! $230/each
SILVER ROCK 35va “Digital” Mains Isolation Transformer $1200/each
The best digital power transformer in the world.
Copper wired or Silver Wired C37 Digital Chokes $260/set or $1200/set
(Use the Silver Rock Silver Signature version in series with the 35va Digital CD Mains Silver transformer for the very best Digital AC conditioning in the world!!! It is completely UNMATCHED)
The power limits of the chokes are 20 watts. So be very careful matching it up to your CD player.
