Making a Sine Wave CD Test Disc
0 Members and 1 Guest are viewing this topic. Read 1539 times.
Mark_Walsh
« on: 25 Apr 2004, 11:14 pm »
Dear All,
I am making my sub-woofer box.  The Drivers have a resonant frequency of approx 21-23 Hz.  I wanted to measure Qes, Qts, Qms but the low cost audio oscillator I have has a gap around the 20 Hz mark ... just where I want to measure.
But if I made a CD with some sine wave signals then the problem would be solved.
I have SoundBlaster Live! with its associated software, and the Win XP and Win 98 stuff, but I cannot find the solution in there.
I have (somewhere) some Midi mixing programs but have never used them.
How can I generate some sine waves (digitally) and put these onto an audio CD to use my lovely CD player as my audio oscillator??
Any thoughts?
MW
randytsuch
« Reply #1 on: 26 Apr 2004, 02:13 pm »
Check out this link
http://www.nch.com.au/tonegen/index.html
it is a tone generation program, will do any frequency you want in sine or other wave forms.  It will output to a wav file, which you can burn to a CD.
Randy
Mark_Walsh
« Reply #2 on: 27 Apr 2004, 09:30 am »
Dear RandyTush,
Thank-you for the lead and link,
Will try it out soon.
MW
