0 Members and 1 Guest are viewing this topic. Read 8644 times.
Try looking at it from the other end. Ask not how high the woofer should go but how low can the 4" mid-range go? The natural roll-off of the mid-range will define the crossover of the woofer.What do you expect to gain by changing the inductor, especially if you arbitrarily change the crossover frequency in the process?
Not interested in nostalgia and I will change anything or everything if I have to. But I would like to keep it simple. The four speakers are wired in parallel.Each branch of the parallel circuit contains a xover component in series with a speaker. The xover components are a .56mH inductor for the bass, a 4uF capacitor for the tweeter and an 8uF capacitor for the 2 midrange drivers.
AE,Talk me through it. I have a wife and kids so I don't have lots of time.Give me your best shot. I just want something simple if that is possible.I am a certified electronics technician but only for aircraft radios and navigation systems. Speaker systems are not my thing.Thanks
AEI have a signal generator and oscilloscope. I am currently bidding on an SPL meter on ebay. The midrange and tweeter already have a potentiometer in series........they were like that when new. I will look for some poly pillow stuffing, I know how to solder very well and nothing really annoys me about the speaker sound. But, always room for some improvement.Thanks
I should have an spl meter by next week and then I will bypass the crossover and do the testing. In the meantime I was looking at the situation more closely and noticed that the two midrange are wired in series. I thought that was strange, but what do I know.The pots or L-pads are wired as voltage dividers. They have three terminals and all are wired. Terminal 1 has 2 wires with 1 wire coming from the cap and the other wire goes to the speaker. The middle terminal (wiper) goes to the speaker. The third terminal has a wire going back to the amp.Next week when I get this meter I will hook up the audio generator and do the testing you suggested. It all sounds pretty straight forward. Thanks.
Moving along.......The 15" bass speaker dc resistance is 5.3 ohms. The 2 midranges are 6.7 and 6.8 ohms and the tweeter is 6.6 ohms. The L-pad is 0 - 50 ohms. I think it is an L-pad now.I have seen hundreds of pots and this does look different. I looked at L-pads on the internet. The feel when turning it is different. There are 2 numbers on it 51-685 and 137-7539.I can send you pics....send me your email. I will take pics tomorrow.AE, I really appreciate the help.
