Denon AH-D2000
0 Members and 1 Guest are viewing this topic. Read 1060 times.
slovell1
Denon AH-D2000
« on: 22 Oct 2011, 08:52 pm »
What would be a good amp for these 25 ohm headphones?
Regards, Sam
Noseyears
  • SS-Audio
    • Supreme Sound Audio
Re: Denon AH-D2000
« Reply #1 on: 24 Oct 2011, 07:04 pm »
Hello Sam,
Whats your source? do you have a budget in mind? let us know..
slovell1
Re: Denon AH-D2000
« Reply #2 on: 28 Oct 2011, 03:37 pm »
Sorry it took me so long to reply, I've been away for a few days. I'm using a Marantz AV-7005 preamp that has it's own headphone section. The Denons do sound quite good with it as the Marantz is no slouch in it's own right. I'm just curious as to what my options are. I rather like these cans, bass is very good and the highs have plenty of sparkle to my ears. They are a bit loose fitting and I have a rather large head but its not bothersome and doesn't affect the sound.
Regards, Sam
eclein
Re: Denon AH-D2000
« Reply #3 on: 28 Oct 2011, 03:47 pm »
A lot of guys are using vintage receivers and similar for the high end stuff nowadays. I'm using an old Kenwood Receiver off and on and it sounds excellent with my HE-5LE's.
Whatever sounds good go with, if it works right now, don't fix it!!!  LOL :thumb:
