KWI 200 Beta Tester Feedback and Opinions Welcome!
0 Members and 1 Guest are viewing this topic. Read 5087 times.
modwright
    • ModWright Instruments
« on: 19 Oct 2011, 07:44 pm »
I have a few beta units in the field now and some information is coming in and I would appreciate opinions from those willing to comment.
1) When unit is powered on, do you want the volume to be where you left it?  I.e. at '20', '50', or whatever volume level you were listening when you shut it off, or at '0'?
2) When u nit is powered on, do you want it to default to inut number one = 'cd', or to the last input selected?
Opinions welcome!
Dan
« Last Edit: 11 Mar 2012, 07:52 pm by modwright »
dminches
Re: KWI 200 Beta Tester Feedback and Opinions Welcome!
« Reply #1 on: 19 Oct 2011, 07:48 pm »
'0'
Quote from: modwright
2) When unit is powered on, do you want it to default to inut number one = 'cd', or to the last input selected?
Last input
modwright
« Reply #2 on: 19 Oct 2011, 08:10 pm »
Thanks, all feedback welcome.
Sincerely,
Dan
johzel
« Reply #3 on: 19 Oct 2011, 09:06 pm »
Hi Dan,
As a person who has one of the show samples "on the way" . . . I'm inclined to go with "0" and definitely "Last Input".
« Reply #4 on: 19 Oct 2011, 09:17 pm »
for me it would be just as it was when I turned it off.
modwright
« Reply #5 on: 19 Oct 2011, 09:26 pm »
OK, so I am getting a general consensus about input being kept in memory - i.e. same as when turned off.
RE volume, if we don't leave it at zero, it would start out at say '10', as an option, rather than exactly where it was when it was turned off.  Because it is a numerical display, you can easily put it back exactly where it was before.
Dan
modwright
« Reply #6 on: 20 Oct 2011, 12:07 am »
I believe that we will hav the volume reset to zero, but will retain the last input in memory.  Further input however is still welcome.
Dan
rajesh
  • Live & Let Live
« Reply #7 on: 27 Oct 2011, 04:46 pm »
Best option is to make both programmable by the user using the remote and setting a preset volume for each input. If that can't be done, better option would be to set it to '0' because, if the amp was switched off after a night of partying, if not by you but your kid, (I won't let that happen but many may) the resultant sound on when you switch on the amp next would be definitely be uncomfortable to your ears.
With regard to retaining the last input or reverting to a default input, last input would be ideal I guess.
P.S. There seems to be some mistake in projecting the power ratings in your website here: http://www.modwright.com/products/kwi-200.php
It says:
200W 8 ohms (.06% THD)
400W 8 ohms (.06% THD)
modwright
« Reply #8 on: 27 Oct 2011, 06:17 pm »
Thanks for pointing out the typ on our website.  It also made its way into the printed literature for marketing  :duh:.
I have decided that the unit will default to the last selected input and volume will reset to zero at startup.
The exception to this being the optional phono and DAC upgrades will have different gain settings, in code, when selected.  d1, d2 will be for DAC RCA and USB inputs and P1, P2 will be for MM and MC phono input with different gains of course.
Dan
johzel
« Reply #9 on: 27 Oct 2011, 06:58 pm »
Dan, any updated timeline on the DAC or Phono upgrades?  Or pricing?  Thanks.
rajesh
  • Live & Let Live
« Reply #10 on: 28 Oct 2011, 02:47 am »
Dan
Good choice there Dan. Sorry about the typo. I wish I had seen the thread when it was started.
modwright
« Reply #11 on: 6 Nov 2011, 06:47 pm »
No worries.  I have corrected all typos on the site for the KWI 200 now, I believe.
I have a press release that will go live on the site, ideally today, but Monday at the latest, about the KWI 200.
We are very busy building KWI 200's that are travelling to:
U.S.
Norway
Singapore
Vietnam
HK/China
France
Australia
Netherlands
UK
It has turned out very well!  I am excited about what we have been able to produce for a $5K US price-point in a 200W high-current (1.5KVA! power transformer) design with optional DAC and Phono upgrades.
Take care,
Dan
rajesh
  • Live & Let Live
« Reply #12 on: 7 Nov 2011, 08:35 am »
U.S.
Norway
Singapore
Vietnam
HK/China
France
Australia
Netherlands
UK
All the best Dan. Are these being shipped to dealers or customers?
modwright
« Reply #13 on: 7 Nov 2011, 06:54 pm »
Most are being shipped to dealers.  We did sell a couple of show demo's from the CO show.  Please contact me directly and I can direct you to our nearest dealer.  If you are outside of the U.S., then we do ship directly to customers in countries for which we DO NOT have distribution.
Dan
