Industry Circles
Bryston Limited
Balanced operation of 4b-st and 7b-st
0 Members and 1 Guest are viewing this topic. Read 2007 times.
guest2521
Guest
24 Apr 2004, 09:29 am »
Does x volts balanced sensitivity (i.e. 3.0 Volts in = 250 watts into 8 ohms for the 4b-st) mean +/- x volts on each of the two pins or does it refer to x volts potential difference accross the two pins i.e.+/- x/2 volts on each pin.
Nick.
Facilitator
The Demo is Everything!
ยป
27 Apr 2004, 12:11 am »
HI Nick,
I will check on that one for you.
james
Industry Circles
Bryston Limited
