WTT Loose Bearing Cup, Adhesive failing
0 Members and 1 Guest are viewing this topic. Read 1666 times.
Neon
« on: 11 Oct 2011, 05:44 pm »
Hi Circle
  I have a WTT Classic w the carbon fiber arm.  The Bearing Cup has the Marigo mod which is a brass clamp which completely surrounds the cup.  The cup was attached to the plinth with a square adhesive coated piece approx 1 inch square by maybe a couple of mm thick which fits between the plinth and the  (almost looks like a double sided adhesive rubber patch) This may have been part of the Marigo mod, done by the previous owner, and the adhesive square actually elevates the cup a little (needed to accomodate the clamp which protrudes below the cup).  Now that the adhesive is failing, any suggestions on how to reattach the cup to the plinth ?
Dana Woods WTT Classic, WTT Reference
Mike Pranka
Re: WTT Loose Bearing Cup, Adhesive failing
« Reply #1 on: 12 Oct 2011, 04:14 pm »
You could use a square of 3M adhesive foam..  or I'd probably just juse a bit of silicone and let it set. The silicone should hold fine and you could still remove the cup at any time if necessary.
Mike
Neon
« Reply #2 on: 13 Oct 2011, 07:48 pm »
Mike
  Thanks much.  Ever hear of this happening ?  What do you think of this Marigo mod ?
Dana
