*SOLD* Von Schweikert LCR-4 ($1,350)
0 Members and 1 Guest are viewing this topic. Read 2183 times.
DKane
« on: 11 Oct 2011, 04:47 pm »
Beautiful & rare full-range Center channel to match the VR-35, VR-4 (SR & Jr), and VR-5 series of speaker models. Original owner, purchased in February 2010 directly from VSA in California to match a pair of VR-4 Jr Mk3's (sold). Light use in a pet/child/smoke free environment. Immaculate condition, state of the art, high performance speaker - comes with original box/packaging, owners manual, remainder of Von Schweikert Audio's 10 year warranty, etc. Serial #014030.
Sealed design and full range capability allows for easy/smooth blending with most subs. Though slightly less expensive when I purchased it, please note that the LCR-4 has a current retail value of $2,495.00.
Specifications-
Dimensions: 9.5" tall x 22" wide x 14" deep.
Weight: 51 lbs raw, approx. 60 lbs packed for shipping.
Frequency response: 32 Hz to 25 kHz (+/- 3dB), flat to 40 Hz.
Sensitivity: 90dB @ 1 watt/1 meter.
Impedance: 4 ohms nominal
Power Handling: 50 - 200 watts rms
Construction: Infinite baffle, sealed box. Triple layered laminated sandwich of resin impregnated MDF, artificial stone, and rubberized felt, 75mm total thickness, with honeycomb internal bracing. Rock solid build, extreme vocal clarity & tremendous, tight bass response.
Drivers: 2-7" Scanspeak woofers with 38mm high power voice coils, low distortion motors, cast frames, copper clad pole piece and long throw suspensions, 1-1" silk dome Illuminator tweeter, with ferrofluid cooling.
Crossover: Fourth Order Global Axis Integration Network using premium film/foil caps, air core inductors, and metal film resistors and Analysis Plus wiring.
Crossover Point: 2,200 Hz
Finish: Piano Black
Warranty: 10 Years.
Please call (850-939-0587) or email ([email protected]) with any questions.  Pictures provided upon request.  If calling, please no later than 9:00pm (CST).  Also please note, my price includes shipping & insurance anywhere in the lower 48.
Thanks for looking.
« Last Edit: 7 Dec 2011, 09:30 pm by DKane »
