FS: Anthony Gallo Due Black pair w/new stands
0 Members and 1 Guest are viewing this topic. Read 1915 times.
KKM
« on: 10 Oct 2011, 07:48 pm »
For sale are a pair of black Gallo Dues with new Due stands, $798 for all. The speakers are are in excellent shape and have no marks, has all the accessories for wall mounting and as table stand. The floor stands have not been used. These speakers and stand are very well constructed and will keep their conditions as new with care since they are all metal unlike other monitors made of wood which can scratch, dent, and mar. The sound is superb, especially the CDT tweeters.
SPECIFICATIONS:
Frequency Response: 80Hz to 40Khz
Sensitivity: 89 dB/w 2.8v (1m)
Nominal Impedance: 8 Ohms
Power Handling: 100 Watts
Driver: 2x3" full range
Tweeter: 180 degree CDT
Dimensions:
Less outer grille 28cm (H) x 10 (W) x 10.5 (D)
With outer grille 29cm (H) x 12.5 (W) x 11 (D)
Weight: 2.6kg
Tweeter Material: KynarT
Full Range Driver Material: Mical Polypropylene Compound
Enclosure Material: Mild Steel
Designed for those who require the ultimate in audio reproduction from a small, wall-mountable speaker. A speaker so versatile it delivers uncompromising sound quality in every installation. Whether wall-mounted or freestanding, Dué delivers a quality and quantity of sound that no other speaker of its size and price can match.
Dué's diminutive dimensions and good looks provide a visual complement to plasma displays and other pieces of attractive audio visual equipment, while architectural sconce-shaped grilles enable Dué to blend into the ambient environment if required.
Custom installation is a breeze, thanks to an ingenious bracket that enables Dué to work anywhere. Whether hidden on a shelf, supported by dedicated floor stands, flush-mounted to a wall and oriented either horizontally or vertically, Dué excels where others fail.
Barely 11" (28cm) tall and 5" (13cm) wide, Dué benefits from patented and proprietary technologies developed by Anthony Gallo for our award winning series of loudspeakers. Based on the best-selling Nucleus Micro, each Dué is comprised of two of these spherically-shaped 4" speakers separated by a patented CDT™ tweeter.
Dué boasts the extraordinary midrange purity of the Micro, combined with the most natural and extended trebles of any speaker on the market. Impressive power handling, 89dB sensitivity, 80Hz-40kHz frequency response and textbook perfect dispersion enable this magnetically shielded speaker to shine in any room, and with any system.
Dué employs our remarkable CDT™ tweeter – widely acclaimed as the finest high frequency driver available.
The performance benefits of CDT™ technology are dramatic. With more diaphragm area than two dozen 1" dome tweeters, our transducer has virtually unlimited output capability. At the same time, the lack of voice coils, coil-formers and surrounds means the CDT™ has a very low moving mass, so it can respond more quickly to high frequency transients.
Finally, its cylindrical shape endows the CDT™ with a dispersion pattern of 180 degrees and delivers the same response off-axis as it does on-axis. For the music lover and the video enthusiast, this wide dispersion means that perfect imaging is not limited to a small "sweet spot".
Buyer to pay shipping and if using Paypal, will split fees so add 2%.
I also have Gallo Micro speakers, accessories, and TR-1 sub available.
