Album art not showing in Mpad
0 Members and 1 Guest are viewing this topic. Read 1513 times.
terrycym
« on: 10 Oct 2011, 10:08 am »
I don't know if anybody else is having this issue but some of my albums don't have album ar :cry:t showng in Mpad.
Problem solved!
Some of my Folder.jpg's were in CMYK format
I saved them in RGB et voila!
Don't forget to refresh the local cache in Mpad afterwards.
Chris/James - I presume for MAX when adding the art within a FLAC file, the format doesn't matter?
Or does it?
« Last Edit: 10 Oct 2011, 08:48 pm by terrycym »
SHV
Re: Album art not showing in Mpad
« Reply #1 on: 10 Oct 2011, 01:02 pm »
"I don't if anybody else is having this issue but some of my albums don't have album art showng in Mpad."
I am and thanks for the explanation.
terrycym
« Reply #2 on: 10 Oct 2011, 01:37 pm »
Has saving your jpg's in RGB mode fixed your issue Steve?
SHV
« Reply #3 on: 10 Oct 2011, 02:22 pm »
Don't know.  Left home yesterday and will be traveling for 2-3 weeks.  I gave the wife diagrams and instructions for operation of the BDA/BDP/IPad combination but asking her to change jpg. format is a non-starter.  :>)
StigO
« Reply #4 on: 10 Oct 2011, 08:16 pm »
What tool did you use to convert?
terrycym
« Reply #5 on: 10 Oct 2011, 08:49 pm »
Photoshop
unincognito
    • bryston.com
« Reply #6 on: 12 Oct 2011, 02:39 pm »
Or does it?
Hi Terry
What ever your web browser can handle is what Max can handle
Chris
terrycym
« Reply #7 on: 12 Oct 2011, 05:13 pm »
Thanks Chris.
