Can I use silver cables for digital IC ?
0 Members and 1 Guest are viewing this topic. Read 1014 times.
oris98
« on: 23 Apr 2004, 11:34 pm »
Hi all,
I am just wondering if I can use the silver cable from take5audio 28 guage with telfon tubing installed as the conductor for 75ohm digital cable ?   I will use it on my DIO.  Is this silver conductor a ture 75 ohm ?  What is the best suitable connectors to use ?  Erichman or WBT ?  For digital use, should I stick with John Risch design or 1 hot and 2 grounds twisted design ?
Many thanks.
