0 Members and 1 Guest are viewing this topic. Read 12627 times.
"Wanna be hipster" LOL Tune the suspension like a Linn. That makes a real difference. If it's not bouncing straight, you'll get better performance in every area, once tuned. You have to adjust the springs from underneath. Each time you turn a spring you have to re-seat it cause it twists. It's a PIA but worth the effort. If you need more details let me know.neo
There's a couple of things you can do to tweak the Systemdek. The first is almost free. If you flip the table upside down and remove the base, you will find that the bearing and tonearm are both attached to a beam that is suspended below the plinth. Pick up some plastic clay or window (rope) caulk and put a healthy coating of the caulk all over the beam. Don't make it too thick as it will over stress your suspension springs. With this tweak you will find that you will get a slightly blacker background. What you've done is dampen the common support of the bearing and tonearm helping to keep bearing vibrations away from the tonearm.
The next big thing is (assuming you have a Rega 250 arm mounted) is to pick up an offset counterweight and steel end stub. Expressimo used to make used to make what they called the Heavy Weight. Since Sal stopped making them, one of the major tonearm companies started making them and for the life of me I can't remember who it is. Anyway, this addition makes a that little RB250 sound pretty darned good. The bass is more solid, the arm tracks much better, it really becomes a fine budget arm.
After that it becomes a lot more labor intensive. Here, you need to fill the underside of the plinth with MDF to add mass. As nice as the the Systemdek sounds, adding mass to the plinth really helps it out. Again, the background becomes blacker. Here, you have to be careful what ever you place below the plinth doesn't interfere with the suspension.
