Panasonic RP-HT360E-S
0 Members and 1 Guest are viewing this topic. Read 1703 times.
Whizzer
« on: 4 Oct 2011, 07:24 pm »
40mm drivers, 40 ohm impedance, half opened, softskin earpads.
Punchy, clean bass (some others have more subbass, most not).
Slightly recessed midrange (should have a THD peak at 4kHz, I don't hear).
Brilliant highs (sounds more detailed than my lambdas, maybe just pseudo).
Earpads are circumaural und quite deep (more place than others, relatively).
WOW factor (at least for unexperienced).
1500mW power (loadwise).
10 feet cable (comfy).
Lightweight (220gr).
Cheap (20 bucks).
Stylish (imho).
One more.
charmerci
Re: Panasonic RP-HT360E-S
« Reply #1 on: 8 Oct 2011, 04:13 pm »
I'm always looking for decent sounding cheap headphones. Thanks. I'll keep them in mind if I need some.
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #2 on: 12 Oct 2011, 08:00 pm »
Im not sure about their build quality, they look fragile. Do you own them?
Whizzer
« Reply #3 on: 16 Oct 2011, 10:45 pm »
The headband/arcs looks fragile, but mine seems stable enough to stand.
The bigger version has a more stable headband, but it's 50mm driver
should have forward mids, weaker upper highs (way above 10kHz)
and should distort early at louder sound pressure levels.
Noseyears
  • SS-Audio
« Reply #4 on: 17 Oct 2011, 05:40 pm »
Since you're a panasonic guy, do you know this model?  :wink:
http://www.amazon.com/Panasonic-RP-HTF600-S-Step-Monitor/dp/B004MMEI8W
I've been reading good things about it.
Whizzer
« Reply #5 on: 17 Oct 2011, 05:55 pm »
This is 'the bigger version'.
The earpads seem to be annoying bigger/deeper
and are probably more durable/better (polyurethan?).
Regards!
