4b pro..... another stupid question most likely!
0 Members and 1 Guest are viewing this topic. Read 2891 times.
redbook
  • the music is the blood...........
« on: 4 Oct 2011, 05:31 pm »
  Hello James and members. I'm getting closer to my new 4b sst sq. purchase. Awhile ago it was said that the 4b received newer and better caps to further evolve the model. (love that) . Does this apply to the pro version as well as the C version? :dunno:
1oldguy
Re: 4b pro..... another stupid question most likely!
« Reply #1 on: 4 Oct 2011, 06:42 pm »
It never hurts to  ask.I remember when the 7B Squared came out.Silly me just assumed that there was a new transformer in them.I was wrong.
Thankfully I waited for the new transformers before ordering.
Assume nothing/Ask everything/It's your money after all.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 4 Oct 2011, 06:51 pm »
YES - although the Pro version has gain controls in the circuit path.
james
redbook
« Reply #3 on: 4 Oct 2011, 09:14 pm »
  Thanks James. I don't suppose the 4b has the newer transformers as well !!!!!!!!! :icon_lol:
rmurray
« Reply #4 on: 4 Oct 2011, 09:17 pm »
 Would those gain controls affect the audio quality? :scratch:
« Reply #5 on: 5 Oct 2011, 12:38 am »
Hi
No the newer transformers only apply to the 7, 14 and 28B's
James
SoundGame
« Reply #6 on: 5 Oct 2011, 02:33 pm »
Hi
James
Not sure if this has been covered previously but would the newer transformers (implemented in the 7,14 and 28 amps) provide any increase in performance in the 4B, if introduced there?  What I'm trying to say is, what influenced Bryston's decision to not roll out the newer transformers across the line - diminishing marginal returns, perhaps?
Is there any intention to roll the new transformers out to the other SST2 amplifiers?  If so, when?
Thanks kindly.
« Reply #7 on: 5 Oct 2011, 03:15 pm »
Thanks kindly.
The newer transformers only make sense in very large powered amplifiers.
james
SoundGame
« Reply #8 on: 5 Oct 2011, 03:24 pm »
james
Understand, so it would be overkill in the 4B-SST2.
« Reply #9 on: 5 Oct 2011, 05:16 pm »
Not over-kill just no performance value and more costly.
james
spinner
« Reply #10 on: 7 Oct 2011, 03:25 pm »
 The gain controls on the pro amps aren't suppose to degrade the signal as I was informed. I assume this to be the case because I like the pro look.  :thumb:
