Audio/Video Gear and Systems
Single Driver, Wide-Bandwidth Speakers
ejfud
Aurasound NS3 measurement
0 Members and 1 Guest are viewing this topic. Read 3252 times.
JohnR
Volunteer
testingtesting
3 Oct 2011, 03:46 am »
On-axis, and off-axis 30 and 60 degrees:
Box is 10 cm wide, so the diffraction peak is a bit above 2k.
In-room response - bass in sealed box seems to be -3 dB at around 85 Hz as predicted by the model:
Not bad for a
$12 driver
(Note: these ones have been sitting on a shelf for years. So the current ones may be different for all I know.)
Any comments or thoughts appreciated
JohnR
Volunteer
testingtesting
Re: Aurasound NS3 measurement
25 Oct 2011, 10:39 am »
I've spent the time since listening to these in a computer/desk setup. Stonking bargain. Assuming you don't mind a bit of EQ, but then again I'm starting to think that about all speakers...
Raiderone
Reply #2 on:
25 Oct 2011, 11:09 pm »
Thanks for the post.
How big are the cabinets?
Yeah, most speakers need some type of eq. I like the adding another driver eq; buy two pair, run one under the other, roll off with single inductor (hopefully).
JohnR
Volunteer
testingtesting
Reply #3 on:
26 Oct 2011, 01:14 am »
Pretty small, about 2.5 liters sealed. It was one I had before. Not a lot of low bass obviously.
Two drivers is a good suggestion. Maybe a bipole would work too.
ejfud
