Squeezebox Touch Linear PSU
0 Members and 1 Guest are viewing this topic. Read 2429 times.
mainscablesrus
    • Suppliers of Hi-Fi & Home Cinema Mains Items
« on: 1 Oct 2011, 07:16 pm »
Removing the SMPS supplied with your touch will improve the sound quality. The Mains Cables R Us SB power supply is an in-expensive solution for those looking for a quick and easy up-grade. We ship globally and can supply 120v-240v dependant on your countries mains supply. We supply a power cord fitted with the appropriate plug for your country too included in the price. The power supply has a captive dc lead fitted, just plug in and go. Also available for Arcam R-Dac, Cambrdge Dacmagic and many more.
Starting at £99.95 plus shipping.
See my website www.mainscablesrus.co.uk to purchase or make an enquiry.
http://bit.ly/qsBE1y is the item in question.
jtwrace
    • TIPP YouTube Channel
Re: Squeezebox Touch Linear PSU
« Reply #1 on: 1 Oct 2011, 07:21 pm »
What's the max current rating?
mainscablesrus
« Reply #2 on: 1 Oct 2011, 07:24 pm »
Sorry should have said, up to 15v DC 1 amp for the £100 version, up to 21v DC 3 amps is £200. Hope that helps.  :D
jtwrace
« Reply #3 on: 1 Oct 2011, 07:30 pm »
Thanks!   :thumb:
Do you mind sharing more specific details about the PS?
Also do you have a 14-28V (24W) supply?
mainscablesrus
« Reply #4 on: 1 Oct 2011, 07:38 pm »
Thanks!   :thumb:
hi
I build them to order based on 240v or 120v input and dc output to suit whichever equipment it connects to, particularly squeezebox touch as the slim devices forum is packed with people complaining that the smps wall wart degrades the sound, I do have choke input psu's that sell for £495 but the £100 ones are more popular! The psu is housed in an aluminium case, fully earthed internally and with an iec socket on the back to accept a kettle lead type power cord, one is supplied with the unit, a captive dc lead is also on the back usually 1 metre log with the correct dc plug attached for your device and a light on the front panel, the case has feet attached, all in all a perfect up-grade for relatively small cost.
I can build a psu to suit anything, fully tested and CE marked, I don't normally do adjustable outputs because the cases need to be larger which puts the price up. If you pm details of your specific needs I can discuss further?
