Which Oppo to Buy?? 93 w/DAC or 95 Standalone???
0 Members and 1 Guest are viewing this topic. Read 4169 times.
johzel
« on: 30 Sep 2011, 12:21 am »
Looking for some advice on whether to purchase the Oppo bdp-93 or bdp-95.  I’m mostly interested in 2-channel listening.  Although, it will be a part of my HT set-up as well.  I already have a Wyred 4 Sound DAC2 so I’m wondering what will provide the best “music” – a Wyred 4 Sound DAC2/bdp-93 combination or a standalone bdp-95.  I'm leaning toward just adding the bdp-93 with the DAC but am wondering if there are any compelling reasons to go with a 95 instead.
Appreciate any suggestions/insight.  Thanks.
Re: Which Oppo to Buy?? 93 w/DAC or 95 Standalone???
« Reply #1 on: 30 Sep 2011, 12:59 am »
Nope. If you using a DAC there is no reason to get the 95.
MttBsh
« Reply #2 on: 30 Sep 2011, 01:02 am »
I recently bought a BDP-93 and it does a fine job hooked up to my DAC via the excellent Wyreworld digital cable.
I think the BDP-93/Wyred 4 Sound combo will compete with - and probably beat - the stock BDP-95, and the Oppos are built to perform well for years... so with the rapid evolution of DACs you can always upgrade your external DAC a few years down the road.
There are some modders doing some exceptional upgrades to the BDP-95 that make it compete with some of the best DACs out there, so that's another option but it'll cost you.
skunark
« Reply #3 on: 30 Sep 2011, 01:07 am »
If you are big into SACDs you still might want the BDP-95 over the BDP-93.
skunark
« Reply #4 on: 30 Sep 2011, 01:14 am »
Oppo already has "one of the best DAC out there".. guessing the mods are upgrades to the output drivers or perhaps other things related to the power supply.   BDP-95 is one of the best rated sources out there, improvements would be marginal at best.
johzel
« Reply #5 on: 6 Oct 2011, 12:31 am »
Thanks for the suggestions.  Will likely purchase a Oppo bdp-93 to pair with my Wyred 4 Sound DAC2 and sell my John Tucker Exemplar modded Oppo bdp-83.   I'm thinking the W4S DAC and Oppo 93 will be equal (or better) than the Exemplar modded Oppo 83???
rbbert
« Reply #6 on: 6 Oct 2011, 12:53 am »
And/or Bluray, of which there will probably be more and more music releases.
Freo-1
« Reply #7 on: 6 Oct 2011, 01:18 am »
I would get the Oppo BD 95.  I have it, and it's perhaps one of the BEST overall buys in audio.  The  two channel analog out is very good.  The mods MAY provide a small improvement at a big price increase that is hard to justify.
