XLR to RCA adapter question
0 Members and 1 Guest are viewing this topic. Read 3128 times.
jackman
« on: 29 Sep 2011, 02:25 pm »
I'm going to try a pro amp for my subs and need adapters.  Purchased a Crown K1 and only have RCA connectors.  Will this work?  Is there another, better, option?
http://www.bestpricecables.com/xlr-3-pin-male-to-rca-female-adapter.html
orientalexpress
Re: XLR to RCA adapter question
« Reply #1 on: 29 Sep 2011, 02:41 pm »
this is a better option ,http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10244
lapsan
Occam
« Reply #2 on: 29 Sep 2011, 03:20 pm »
Yup.... it will allow you to use your present rca cables, assuming you like their bass performance. I'd probably use a Neutrik version of the adapter, as I'm familiar with the quality of their products, but it would be about twice as expensive.
Russtafarian
  • Typical reaction to the music I play
« Reply #3 on: 29 Sep 2011, 03:47 pm »
I agree with Paul, get the adaptor with neutrik connectors.  It looks line the bestpricecables link is neutrik.  Cheap XLR connectors will either crumble with regular use or melt when soldered.
Here's a potential issue to be aware of. RCA to XLR adaptors are wired as follows: signal + from the RCA goes to XLR pin 2 and signal - goes to XLR pin 3 and pin 1 (XLR ground).  If you connect the amp with the adaptor and get ground loop hum, you may need to lift (disconnect) pin 1 from pin 3 inside the adaptor.  Signal - from the RCA should still be connected to pin 3 of the XLR.
TomS
« Reply #4 on: 29 Sep 2011, 04:07 pm »
I have used these from this Audiogon seller "Ehous" with my DCX for years with no problems.
http://www.audiogon.com/cgi-bin/cls.pl?accstwek&1320247041&/Xlr-To-Rca-Adapters-Gold-Conta
Big Red Machine
« Reply #5 on: 29 Sep 2011, 07:11 pm »
These are very nice and the gender options are very helpful allowing you to be flexible.  I own some of these.
tomytoons
« Reply #6 on: 29 Sep 2011, 07:24 pm »
Those are good, I also own some of those.
I think I did lift the wire too. I was using them on my Benchmark DAC1 at the time.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #7 on: 29 Sep 2011, 07:49 pm »
Tom's right. I got these from Ehous and they are great.
Anand.
