ground loop isolator added hum?
0 Members and 1 Guest are viewing this topic. Read 2248 times.
Rclark
« on: 27 Sep 2011, 10:56 pm »
 Was in Radio Shack and bought an isolator just to try it because my DAC has a mechanical hum at times noticeable when everything is off.
 I plugged this thing inline between the dac and my amp and bzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz it didn't work at all. Actually added a very loud hum/buzz. Seemed to have an effect on the audio but didn't leave it in long enough to guage.
 Am I using it wrong or do I need to return it?
Speedskater
  • Kevin
Re: ground loop isolator added hum?
« Reply #1 on: 28 Sep 2011, 03:29 pm »
An analog audio signal isolator won't have any effect on a mechanical problem.
Try again using plain-jane analog audio co-ax interconnects.
Æ
« Reply #2 on: 28 Sep 2011, 04:06 pm »
Take a look at this schematic, drawing. It shows a circuit for removing/blocking DC that might be polluting your AC power and getting into the equipment power supply. Apparently at times DC can ride along on the AC mains and cause transformers to vibrate etc. If the pic is too small to see, print it out.
Speedskater
  • Kevin
« Reply #3 on: 28 Sep 2011, 05:04 pm »
Take the DAC to a friends house in a different neighborhood and see if you get this mechanical hum.
Many "DC" offset problems are intermittent depending on if the offending device causing the problem is on or off.
srb
« Reply #4 on: 28 Sep 2011, 05:21 pm »
If the hum isn't due to DC offset and the transformer is a toroid, sometimes loosening the center bolt and rotating the transformer a few degrees and retightening can help.
Rclark
« Reply #5 on: 29 Sep 2011, 07:09 pm »
Eh, I returned it. But I will try that last one.
